KuMX
Ku
Socal
Cybertruck AWD + 2017 Model X
The Cybertruck battery is 4 x 200V units in series. A switch inside allows switching between parallel and series to optimally charge at 400V and 800V
Tesla Cybertruck Cybertruck battery is 4 x 200V units in series. Switch inside allows switching between parallel and series to optimally charge at 400V and 800V 9pkaf9tzyp3c1
Source: 31 minutes into this video
Knucklehead
Virginia
Mustang Mach-e, Jeep GC-L, VW Jetta
That is freaking awesome and exactly the right way to design the pack. The Lucid uses a converter when the charger cannot provide 900V, which results in a very slow (like 60 kWh or less) charge speed on 400V chargers.
Diehard
D
U.S.A.
Isn’t the parallel, series switch how GM is doing it with hummer and Silverado? What is different/new here?
Yeah, I thought Rivian had that patent.
Anyhow, it's kind of the way to go. Just like taking AA batteries out and swapping them into the charger. Charger charges at one voltage, your toy operates at its voltage.
GhostAndSkater
Earth
None
Yes, but if I remember correctly, they use a bunch of stand alone contactors to make it happen, more expensive and bulkier, Tesla designed a single tiny switch that integrates all that
fhteagle
Telluride, CO
2013 Volt, CT Res x2
I wonder if one of the 4 "packlets" (modules?) be replaced independently, or if they have to be replaced all four at once.
They should all wear out at the same time.
The powertrain warranty, including the battery, is warranteed for 150,000 miles/8 years. If Tesla is comfortable not having indivdually replaceable modules when it's on their dime, then I'm not worried. Drive the pack until until it no longer has adequate range, and then put all new batteries in it.
Tesla learned a long time ago it doesn't make economic sense to mix new and old batteries.
scottf200
Western NC
X; immed family 3 & Y
350 kW on v4 superchargers - from official Tesla folks
34:00
intimidator
TJ
Alexandria, VA
2023 Ford Lariat Lightning
I was very happy to see the 150,000 mile warranty.
Hope no one ever needs it, but that is a nice bump in the warranty.
davelloydbrown
Dave
model 3, silverado
veterinarian - retired
If there is no 12 v circuit, how it is going to run the lights and brakes when towing a trailer?
Bluechip506
Steve
Cypress, TX
Tesla Model S, Mazda CX9, Mazda Miata
I think our Model S came with 8 year unlimited milage on the battery which has 1 year left. So far so good. Minimal degradation. Almost 100K miles. 259 miles stated originally (actual was around 235), and now it's about 225 actual.
