Cyber Man
I am a HUGE Cybertruck fan.......but your logic/reasoning is bad. Real bad. Makes no sense. Probably need to delete IMO.
Yeah I know! That’s why I posted AI analysis that says exactly what I say in a much better way. The explanation is really good, if someone has the patience to read without trash talking about it as AI garbage.
What’s really bad is saying it’s bad (CT chassis is unsafe/questionable for towing) without telling why it’s bad based on scientific evidence!
CyberTexas
Great state of TEXAS
FS CB White Decor Cyber Wheels
Physician
AI searches the web for explanation. It does not analyze the sources for validity. AI, such as Chatgpt, is great for known knowledge. Otherwise, it is simply gathering the words related to the search topic on web.
What you wrote is utter nonsense. I love CT. VERY CLOSE to getting CB Foundation. But I know it’s weaknesses and strengths…or at least learning at much as I can. Towing is not its strength. It will do in a pinch or lighter loads but your explanation just hurts my head.
Cyber Man
These type of FUDs without logical explanation hurts my head. Have you towed with CT? I have towed with my Beast. Please don’t make assumptions. All EV trucks have limitations (aero drag). Saying Aluminum chassis is CT’s towing or hauling limitation is utterly nonsense. That’s the core issue of what’s getting debated in that video and this thread.
Skeptics are saying Steel is better than aluminum blah blah. There are other members on this forum who have towed boats, RV trailers, dump trailers, hauled heavy weight etc, including long distance towing. You being future Cybertruck FS buyer has nothing to do with Truck’s towing or hauling capabilities.
Please research a bit more on aluminum alloys, fatigue tests, OEM skid plate tests, chassis stiffness vs swaying, crumble zones, etc, or at least read through ready-made compiled information shared by other members. If all this science hurts your head, there is always ignore button! ?
CyberTexas
Physician
But that is the point…CT is barely over a year old. No one and I mean no one has done enough towing to back up what you are saying about fatigue and aluminum.
The question is not if CT can tow 11k lbs. it is longevity of towing that much. And that answer is still up in the air.
But your explanation about breakaway crap is just wrong. That trailer just detaching in a frame failure is a “safety feature”. Blah blah. Come on man. There is nothing that should breakaway when towing a heavy load! Nothing.
Will CT cast Alum breakaway? I have no idea. I hope not. I do not plan on towing anywhere near 11k lbs. I am a believer of 70% role…and even then, I will tow seldomly. So for me, this whole topic is not deterrent to buying one.
As for EV and towing, there are plenty of negatives that towing is simply not a strength at this time compare to a gasser/diesel.
BannedByTMC
NYS
lol, every post I made on this thread is to share facts that I sourced to be true and not a rant.
This was nothing more than a personal attack and not factual ?
I can’t help those who twist facts to fit their feelings. You want to feel that CT is not good. You are disproving the data shared by fellow members, or AI, or even Tesla lead engineer who built Cybertruck, by just copy pasting link to a half-baked YouTube video. Every data point I shared above is to debunk the myths in that video. The video does ask good questions but the answers are nuanced.
You want to side with those who validate your false narrative and spread FUD about Cybertruck design and safety! Can’t help you further! Sorry buddy!
You created a false fantasy in your head of my motives for posting, don't pretend your delusions are "facts".
wshunter
William
S. Illinois
Tesla model Y, Cybertruck
I am fairly sure most states, if not all states require trailer brakes over typically 3500 lbs gvwr on the trailer. So getting the 11k on the trailer hitch would ONLY be possible from towing INCORRECTLY and, at that point, illegally. At least, from the braking discussion.
That being said, the fatigue stress failure is real and, for that reason alone, I wish tesla would have made that subframe out of steel instead of aluminum.
Now the graph that shows the cycles vs failure is an ideal case and does not account for how steel reacts over time, ie rust/corrosion. Everything fails at some point. There are pros/cons to each. The biggest concern I have for my CT is actually the aluminum to stainless steel interface. The electronegativity difference between those two metals WILL result in the stainless steel eventually corroding away, aka galvanic corrosion. How long will depend on how those joints, ie is there paint/rubber inbetween those interfaces and how abusive of an environment the truck is maintained, are connected. I have been half tempted to try and attach zincs to portions of the truck at the steel/aluminum interface to try and minimize the possibility of galvanic corrosion.
Edit: spelling
Here in the rust belt, I have had two pickups almost literally rust out from under me. Case in point, I had a large oak log loaded on a flatbed trailer attached to my teenaged Nissan pickup; left it overnight. Next morning when I went to move it, I thought I had a dump bed on the truck. I hadn’t realized the frame had rusted enough that it broke in front of the rear wheels and the hitch and trailer tongue were on the ground. I know aluminum corrodes too, but just agreeing that there are lots of variables. The concern about galvanic corrosion is interesting. I have my concerns about the stainless panels being “glued” on instead of mechanically fastened. With the adhesive separating the stainless from other metals, it seems the galvanic interaction would be minimized or eliminated. Maybe the engineers thought if that??
Bridgeboy69
Trying to Survive
and then went rambling about stainless steel exoskeleton which is irrelevant considering the hitch receiver is bolted to the aluminum casting which is the main stressed element when towing.
I don't think anyone here, including the YouTuber, knows what is, or is not, relevant in the design of these CyberTrucks. The engineers on the CT team at Tesla know. They likely have advanced 3D models of how all forces spread around and through all of the truck's components, compositely, in every conceivable loading scenario. The fact that all their other models of vehicles are #1 is safety should imply this. The exoskeleton could very well likely contribute to the stresses that get imposed upon the hitch area.
In any case, I took @Cyber Man 's reference to the the exoskeleton as an example of the of the extreme engineering, and high-level of sophistication that the Tesla engineer's go through…and not to imply it was, or was not, relevant to the hitch, because he doesn’t know. (Even though I believe the SS was engineered at SpaceX, but still another Musk company, which all excel in extreme competence, and his companies work synergistically with each other). They likely have not overlooked some critical detail in the hitch despite some YouTuber claiming it is possible.
My money is on the Tesla engineers. I am not worried about it in the least. There are so, so, so so, so many other things more important to worry about, and I don’t worry about more than half of them either...
BannedByTMC
NYS
The hitch ripped off with no damage to the body panels, that means no stress transfer between them. You don't need to be a Tesla engineer to understand engineering.
Bridgeboy69
Trying to Survive
Well, I am an engineer, and just because the steel exoskeleton did not suffer damage does mean at all that they do not contribute to the forces that get expressed on the hitch. They can flex at certain points to reduce force upon the hitch based upon how they interact as a composite system together. The fact that the hitch was the failure point means nothing in this regard.
But anyway, read this point again:
Bridgeboy69
Trying to Survive
I disagree
Well good for you, but you're wrong. All components that are structurally attached to each other interact with each other structurally. We already know Tesla designed the exoskeleton to contribute to it's structure, hence terming it "exoskeleton." Which is unique among all consumer vehicles created to date. Not all components have to fail to show they contributed to the overall structural behavior.
By your logic when a single link breaks in a chain, the fact that all the other links did not fail proves they did not contribute in resisting the load.
You are the one in this thread that makes no logical, common engineering, sense.
You come across like a planted Cybertruck FUDer. I am genuinely curious why you're even permitted to be here since I had to prove to the moderators I owned a Cybertruck before I was permitted to post here myself.
BannedByTMC
NYS
Front bumper is "structurally attached" to the rear by the rest of the truck, did it contribute anything? Just because Tesla called it an "exoskeleton" doesn't mean it really is one.
Maybe they aren't afraid of someone pursuing the truth instead of fan boying. If not they can of course ban me. As I've said I have a vested interest in the company succeeding as a vehicle owner and a shareholder.
The sails provide a load path from the rear towers to the forward mast.
The failure appears to have broken the tower spot welds. So that level seems fairly high, but stronger might not have helped. The sail is a stainless piece on a bracket, so we can't see if there was deformation of the underlying material that allowed higher forces on the casting before failure.
Tesla Cybertruck Cybertruck hitch analysis by Engineering Explained SmartSelect_20250419_173648_Firefox
Tesla Cybertruck Cybertruck hitch analysis by Engineering Explained SmartSelect_20250419_174331_Firefox
Tesla Cybertruck Cybertruck hitch analysis by Engineering Explained SmartSelect_20250419_173309_Firefox
Bridgeboy69
Trying to Survive
Possibly, I don't know, and neither do you, and especially not that Youtuber.
Only the Tesla CT team members that designed the Cybertruck are qualified to know how everything interacts with each other.
But your comment of this:
Shows your general ignorance of composite structural behavior. If my chain and failing chain-link analogy doesn't get that point across in layman's terms to you, I don't think anything will.
You bringing up the front bumper relation to the rear bumper just shows your dedication to FUD this thing at all costs. You are grasping at straws now.
Bridgeboy69
Trying to Survive
Here ya go...using AI is the best option we have right now since we aren't Tesla engineers that designed this thing:
Asked to GROK: What degree of structural contribution does the SS exoskeleton provide to cybertruck's structural integrity?
Grok's Reply:
The Tesla Cybertruck's stainless steel exoskeleton provides a significant structural contribution to the vehicle's overall integrity, acting as a primary load-bearing component rather than just a cosmetic or protective shell. While precise quantitative data (e.g., exact percentage of structural contribution) is not publicly disclosed by Tesla, the following details outline its role based on available information:
Key Contributions of the SS Exoskeleton:
1. Primary Load-Bearing Structure:
- The exoskeleton, made of 30X cold-rolled stainless steel, is designed to carry a substantial portion of the vehicle's structural loads, including torsional rigidity, bending stiffness, and crash resistance.
- Unlike traditional vehicles with a separate body-on-frame or unibody structure, the Cybertruck integrates the exoskeleton as a core structural element, reducing reliance on an internal frame or chassis for strength.
- Elon Musk has described the exoskeleton as providing "most of the structural integrity," with the internal frame serving a secondary role, primarily for mounting components like the battery pack and suspension.
2. Torsional Rigidity and Stiffness:
- The exoskeleton's thick (1.4–1.8 mm) stainless steel panels contribute to exceptional torsional rigidity, which is critical for handling off-road stresses and maintaining stability under heavy loads (e.g., towing up to 11,000 lbs).
- Its monolithic design, with fewer welded seams than traditional unibodies, minimizes weak points, enhancing overall stiffness. This is evident in demonstrations where the Cybertruck resists deformation under extreme conditions, like towing or off-road impacts.
3. Crashworthiness and Impact Resistance:
- The exoskeleton's high-strength stainless steel (with a yield strength estimated at 1,500–2,000 MPa) absorbs and distributes impact energy, protecting the occupant cell.
- During crash tests, the exoskeleton's dent-resistant and rigid properties help maintain structural integrity, reducing intrusion into the cabin. Tesla's simulations and early crash test leaks suggest the Cybertruck meets or exceeds safety standards, partly due to the exoskeleton.
- The angular, faceted design further aids in deflecting impact forces, complementing the structural battery pack's contribution to crash energy management.
4. Integration with Structural Battery Pack:
- The exoskeleton works in tandem with the Cybertruck’s structural battery pack, which is bonded to the floor and acts as a shear plane, further enhancing rigidity.
- The combination of the exoskeleton and battery pack creates a "dual-shell" structure, where the exoskeleton handles external loads (e.g., impacts, torsion), and the battery pack contributes to longitudinal stiffness and energy absorption.
5. Weight and Material Efficiency:
- By using the exoskeleton as a structural component, Tesla reduces the need for additional internal bracing or a heavier frame, optimizing weight while maintaining strength.
- The stainless steel’s durability eliminates the need for a separate corrosion-resistant coating or sacrificial components, indirectly supporting long-term structural reliability.
Qualitative Degree of Contribution:
- The exoskeleton is estimated to provide 60–80% of the Cybertruck’s structural integrity, based on Musk’s statements and engineering analyses from teardown experts like Sandy Munro. The remaining contribution comes from the structural battery pack and internal castings (e.g., front and rear gigacastings).
- Its role is analogous to the SpaceX Starship’s stainless steel skin, which also serves as a primary structural element, suggesting a design philosophy of maximizing material efficiency.
Limitations and Trade-Offs:
- Weight Penalty:
The exoskeleton’s thickness and material density make the Cybertruck heavier (6,600–8,000 lbs) compared to aluminum-bodied competitors, potentially affecting efficiency and range (301–320 miles).
- Manufacturing Complexity: The exoskeleton’s hard-to-form stainless steel requires specialized processes (e.g., air bending, laser cutting), which may limit repairability and increase production costs.
- Vibration and NVH: Some users on forums like Reddit note that the rigid exoskeleton can transmit more road vibrations compared to softer unibody designs, though this is mitigated by the suspension and battery pack.
Supporting Evidence:
- Tesla’s Claims:
Tesla’s website and Musk’s presentations emphasize the exoskeleton’s role in making the Cybertruck “bullet-tough” and capable of withstanding significant external forces (e.g., sledgehammer impacts, 9mm bullet resistance).
- Teardown Insights: Early analyses from Munro & Associates suggest the exoskeleton’s integration with gigacastings and the battery pack creates a “fortress-like” structure, with the exoskeleton handling most external loads.
- X Sentiment: Posts on X praise the exoskeleton’s durability, citing real-world examples like the Cybertruck surviving high-speed collisions with minimal damage (e.g., a reported 75-mph crash with only superficial dents).
- Engineering Context: The exoskeleton’s design draws from aerospace principles, where skins contribute significantly to structural integrity (e.g., aircraft fuselages), supporting claims of its dominant role.
Conclusion:
The stainless steel exoskeleton is a core structural component, likely contributing 60–80% to the Cybertruck’s structural integrity, with the structural battery pack and gigacastings providing supplementary support. It excels in torsional rigidity, crash resistance, and durability, making the Cybertruck exceptionally robust for its class. However, its weight and manufacturing complexity are trade-offs. For precise data, Tesla’s engineering disclosures or third-party structural analyses (e.g., IIHS crash tests) would be needed, but these are not yet publicly available as of April 19, 2025.
Go ahead an give your best FUD denial of why this response is totally unreliable. I know it's coming...
