For easier cleanup after the video maybe. Because I notice they didn't show That part - so they could have used an air-pressure-actuated tilt dump bed - now to come standard on Cybertruck II.Who dumps cinder blocks into a bed?
show 2 yards of gravel or sand being loaded in a commercial yard
maybe didn’t think about it enough
having the tailgate down to dump even something innocuous like mulch defeats the purpose of dumping in the first place.
having the tailgate up, and for things like gravel, you’re not now only deciding on dumping material on just just the top plastic of the tailgate, but also the rear roofline of the cab. Maybe more to the point, you’re also now WAY more concerned about who ver is piloting that loader.
And regardless, the needle-threading described above is all and only about a standard sized compact loader bucket at 60”
if your yard isn’t running compact buckets that day, or doesn’t run compact front loaders any day, you’re now that much more worse off. There are trucks with a standard 5.5’ bed not
not a huge deal. Just raised/ emphasized bu this block dump
The genius of a sloped roof and armor glass are evident now.Time for tesal to add a cyber funnel to their kit bag.
2 yards is 3800-4000 lbs!Who dumps cinder blocks into a bed?
ive done the proportionate equivalent in my prior ICE F1502 yards is 3800-4000 lbs!
What kind of idiot would put 2 tons in a 2500 lb rated payload?
I assume that someone would be more worried about the glass roof than the tailgate. So I would merely ask the operator of the loader to give more room on that side and i'll happily let some stuff fall off the tailgate and onto the ground. If it seems like it'll be a lot, I'll grab a shovel myself to scoop it up.maybe didn’t think about it enough
the same type of idiot that would dump a bucket of cinder blocks into a truck2 yards is 3800-4000 lbs!
Definitely no different a concern than in a rivian, which also has a bed too small for a loaderAnd as for concerns for who is operating the loader. I don't see why that would be different than lets say a Rivian.
I too have an F150, the reason CT is unharmed is simply the composite bedliner in CT. The Tacoma, Tundra, Sierra 1500, Ridgeline and several mid-sizers have that optional or standard. It’s a cool feature, the downside is it’s slicker than snot when wet compared to most alternatives. Toyota actually started offering a spray on liner over top of the composite to counter the slickness.I think the point here is it didn't damage anything. That would have put a big dent in my rhino liner bed of my f150 and i have the steel bed. Do people pick up gravel in pickups in your yards? I cant believe people do that. $30 a load for delivery here and they will dump it right where you need it. Costs me more money to drive the trailer out there to pick it up.
I'm still wondering where you are getting 59" from.Definitely no different a concern than in a rivian, which also has a bed too small for a loader
and better than Rivian in terms of the SS
More common effect of the 59” bed will be what cargo fits with tailgate up (eg boxes)
I can't say that it isn't, but it doesn't appear to come out that far in videos that I've seen where they get a closer look at that location.
