zeke
- Zeke
- Mar 11, 2024
- New Hampshire
- Model X Plaid, AWD Foundation Cybertruck
- Occupation
- Software Engineer
- Thread starter
- #1
A little unconventional, but I set out to build my own cargo divider just because. It was a quick prototype that I ended up sanding and staining as I won't have time to build a more "proper" one for the time being. I think it turned out pretty good!
It's made of white pine (though any softwood would work), and uses some standard L-track hardware. While not as fancy or quick to move as the OEM divider, all it takes are two hand screws to set/remove.
Parts list with cost:
- L-track threaded attach points: 2 for $12 (https://www.amazon.com/gp/product/B07W8ZXHYB)
- Thumb screw bolts: 2 for $9 (https://www.amazon.com/gp/product/B0CRZ9F9KQ)
- About as much wood as two 2x4s (8 foot) would yield, so like $10 except that I make my own wood so it was free for me
Total: $21 + some for the paint
Pros:
- basically free
- very light cause it's pine
- can be extended to have 2 more attach points at the bottom and flipped 90 degrees to act as a table
- customize the height if you have a floor mat
- DIY
Cons:
- none, this thing is great
- fine, it'll snap in two if you smack it hard enough, but then I'll just make another for free as the hardware won't go anywhere
Pros:
- basically free
- DIY
Cons:
