That Beast Mode
Phil
New Jersey
So why not make this 100% inphil?
lol... It would use a shit ton of material and take 3 days to print. It's also not necessary, the lever is pretty darn strong as is - it was the layer that was an issue, but the nut and bolt thing should solve that.
CyberGlow
Chicago
www.getcyberglow.com
2025 Tesla Cybertruck
Tick are you the original designer of it?? I have a Bambu P2S so it is an enclosed printer. I just got it like 2 months ago, so all my materials are new - I did however do a drying cycle on the AMS 2 before using it. I didn't mess with nozzle temp tho - what temp do you recommend?
I’m also using a P2S with 11% humidity
TickTock
Phoenix, AZ
Electrical Engineer
Yup. That and there have been many studies showing diminishing returns above 50% and even less strength at 100%.
Tesla Cybertruck Emergency Exit Rear Door Release Ideas 1769709629196-z9
CTOmaha
Nebraska
CT FS AWD, MY 24
Exactly what TickTock said, 100% infill could lead to even more layer adhesion problems.
I have a system going now for drying filaments after having adhesion, stringing and blob of death issues. I have this that does the "pre" drying for 48 hrs, I can have four rolls in it.
https://a.co/d/ggiAMpe
Then I have two of these, so I can line up rolls in order of usage, I set to PETG for 24hrs before using the roll. Then, I set it to a lower temp around 122 degrees while printing. Keeps the humidity down around 10%.
https://a.co/d/4Q8QucY
It's been working great.
CyberGlow
Chicago
The new Bambu Studio update allows for dry filament while printing and setting up drying via the Handy app
TickTock
Phoenix, AZ
Electrical Engineer
Humidity looks pretty good. Find something small to test with and try increasing the nozzle temp +10 to +15C. That should help. If not try slowing it down. I am not familiar with Bambu, but Prusa provides a couple profiles: stay away from the speed profiles - those are great for quick prototyping prints that don't have to be strong but not good for final prints. I customized the "structural" profile a bit further ("STRUCTURAL - TT" below) to change the infill to 40% Triangular (triangular is stronger than rectilinear).
Tesla Cybertruck Emergency Exit Rear Door Release Ideas 1769710263843-kv
CTOmaha
Nebraska
CT FS AWD, MY 24
Speed and temp make a huge difference. Printing at 250 centigrade and speed slowed down has led to less issues. It does take 2 hours and 20min to print two of these on my printer though.
Tesla Cybertruck Emergency Exit Rear Door Release Ideas 1769710912913-ku
TickTock
Phoenix, AZ
Electrical Engineer
I would also make a further comment. Whether due to poor layer adhesion or a surge of adrenalin, if someone *was* to break the lever, the pull loop is still there, clearly identified. So they would just grab it and pull. Still a big improvement over the OEM hidden loop.
This is been an interesting experience for me. When I first shared this model I was actually expecting to get flamed by the fan boys. I knew some folks would want it so I went ahead and posted. Just goes to show you never know...
