Hazard lights STUCK ON & I cannot turn them off! 😮
Blu_Beauties
2024 Tesla Cybertruck Cyberbeast
Sales
***EDIT*** (Issue resolved, explanation below)
Hey guys,
I picked up my Cyberbeast Tri-Motor Truck last Saturday, March 23rd here in California.
I brought it to be wrapped and have the windows tinted. Upon picking up the truck everything was fine. I drove about 20 minutes to get dinner and I parked the truck and locked the doors and went inside.
About an hour later I come outside to see that the hazard lights were blinking, and nothing I do is allowing me to shut them off. ?
I’ve tried all of the basic stuff like a soft reset using the scroll wheels, powering down the vehicle using the touchscreen. I’ve even gone as far to unplug the touch assembly control unit following the instructions in the owners manual (found here). Unfortunately, even after disconnecting the unit and plugging it back in, the hazard lights continue to remain on. I’ve tried calling technical support, and the only thing they offered to do is have the vehicle towed, but since it’s still drivable, I didn’t want to do that and I drove it home.
I have it plugged in on the charger right now, and other than the hazard lights, blinking, there is no indication on the dash, no notifications in the system, nothing at all to indicate that there’s a problem, and absolutely no way to shut them off from the screen. It’s pretty unfortunate that Tesla doesn’t have any other way to turn them off other than the touch sensor on the overhead console.
Anyone have any ideas? I guess I’ll need to drive it into the local service center tomorrow with the hazard lights on the whole time. ??‍♂
Update:
I’d like to report that I was able to find the issue, isolate it and address it so that the hazard lights turned off. It’s important because if someone else comes across the same issue, I want them to find the solution as well.
Upon having the front windshield tinted, a little bit of water got inside of the assembly unit above where the hazard lights are located. Since it is a sensitive hazard light button, I’m assuming that the small amount of water underneath caused it to malfunction.
I removed the assembly carefully, and unplugged it, took it inside my home and sprayed some isopropyl alcohol on the inside and used a blow dryer and compressed air to get any residue of water out from the inside.
After giving it about an hour to dry and plugging it back in, the hazard light button was responsive again and all is well. I hope this helps for anyone else that might get into a similar situation after having their window tinted.
djobleezy
Kevin
Model S, Model 3, Cybertruck
Others have been having similar issues, solution is to go to the SC to get it fixed. What VIN range is your beast?
FutureTruck
GA- USA
Tesla MX P, Lucid Air GT
Don't drive much, driving with hazards on is a non-moving violation in most states.
I just activated my hazards and tried the scroll-wheel reset, the brake+scroll reset, and even "Controls->Safety->Power Off". The hazards kept blinking the whole time. There's nothing about it in Service Mode.
My next suggestion would be to Power Off, and then disconnect the LV battery. If they keep blinking after that, you will need 2 priests
C T Rick
Rick
2008 Dodge Sprinter 3500, 2015 Nissan NV 3500, 2013 Chevy Traverse
Plumbing Contractor
As if the CT needs more attention on the road. Hazard lights would say, Hey look at me, I’ve got a Cybertruck.
Have it towed into your service center unless you’re just blocks away.
Rick
Art138
Art
Weston,Florida
MYP,Ford GT & FS CYBERBEAST
I would insist that the mobile service come to your residence and fix.
ModelCYBR
Low voltage and high battery voltage may resolve it. Disconnect is easy in the frunk. Just pop the top trim and unplug high voltage first then 48v
Blu_Beauties
Blu_Beauties
Sales
The hazard lights are supposed to keep operating even when the rest of the truck is dead, so it sort of made sense that they'd be able to operate independently of the truck's main computers.
So your working theory is that the moisture was making it act like someone was pushing the button repeatedly?
