PowerShare gateway malfunction
loki
localhost
My powerwall gateway started going crazy today. It started banging and knocking loudly. Enough the shake the house and make the lights flicker. It stopped after about an hour at which point I noticed the charger did not work anymore and the gateway is offline.
Per my electrician it was from a bad Tesla firmware update. Guess I have no charger for now. Still waiting for PGE to approve the PowerShare and install the final disconnect piece.
loki
localhost
Electrician called. Apparently Tesla told all their electricians need to disconnect communication cable from chargers tonight asap so they can push firmware update. Physically go to every single customer by tonight.
IDK about the need to "disconnect communication cable from chargers", my PowerShare has a breaker for the WC that I will turn off for tonight, just in case.
Not sure what damage the comm wires can do when the circuit has no power...?
loki
localhost
Apparently it will keep the firmware update from succeeding.
CyberPug
SoCal
Architect
The electricians came and disconnected the low voltage wires inside the gateway.
The charger works, but the powershare is deactivated as well as the the power monitoring from the app.
These guys are running around to all the installations tonight to take of this issue. Interesting.
loki
localhost
My electrician is on his way over now. They’re definitely busy tonight. Wonder how much Tesla is comping them for their issue.
SIRMIXARAM
Houston
Mercedes S550, ordered CyberBeast
On a side topic, I approved my quote from Qmerit and I ordered my power share gate way and universal charger. I recieved the universal charger but the Powershare gateway still does not have a tracking number. It’s will be 6 days on Wednesday since I ordered everything. How long did it take everyone else to receive the gateway?
loki
localhost
My electrician brought both
SIRMIXARAM
Houston
oh ok yours must have been earlier, I believe they changed the method where now it ships to the customer. How long after you approved the quote did the electrician bring it to your home?
loki
localhost
I intentionally scheduled out an extra month and a half to prep the area of install
I'm going to tell you guys this right now, this is absolutely corporate espionage. No way anyone "accidentally" sent out an errant firmware like this.
igs
CT, MX, MY
Elon needs to fire more people.
MyFirstElectricTesla
SoCal
Benz
We got the same problem from this morning. Called Trout Electric, I guess I was the first one because they put me on hold for a while for finding out what was wrong, and they sent a tech to work on it around 3:00 PM.
