Pops
- Dec 31, 2023
- Houston, TX
- MY, CyberBeast
I have 6.4kw of solar, 32kWh of batteries and a 12kW (240v) inverter sitting in my garage waiting to be installed in my trailer. The purpose was to be able to tow with the CT somewhere to go camping and leave with more charge then when I got there. I will make a thread about it when its done.Weight appears to be 182 lbs for the basic 6 kWh battery (112 lbs) plus inverter (70 lbs). Add 112 lbs for each additional 6 kWh battery, so should be 294 lbs for 12 kWh or 406 lbs for 18 kWh.
If you carried this in the bed, you wouldn't be able to charge the truck while driving. But you could do so overnight while parked, and it would be a lot quieter than a portable generator. Significantly more expensive though.
Even the 400-lb 18 kWh version, which is available for $8,000 (without panels), would only represent a relatively small fraction (like 15%) of the CT's 122 kWh battery capacity.
Practically speaking though, you cant charge while moving, and even 32kWh of batteries is <80 miles of driving (not towing). 6.4kw of solar will take 4 perfect days of sun to charge a CT from empty to full. So this really only helps if you camp for around 1 week at a time, and it doesn't "extend" your range like the RE would have.
The holy grail would be tapping directly into the high voltage 800v lines of the CT and connecting a 800v battery bank to it. That's what the RE would have been. If you are able to carry the batteries in the trailer, it would be ideal for towing. No weight or space penalty to the bed of the CT.
