CyberZephyr
Long Island, New York
2021 MY, 2023 MX
Starlink is the perfect accessory for the Cybertruck, it should've shipped with it!
EXPTREVER
Trever
Folsom, CA
Cybertruck, S, 3, X, Y
When I need mine in the vehicle for travel I just place it in the dash behind the screen facing outward. I have a cheap rubber mat that I set it on and it doesn't budge or scratch the dash. Cheap and super effective way to use it. Not sure why you would need it permenantly attached to the truck since the truck can't seem to be connected to wifi while driving.
MoabChris
Chris
San Diego, CA
2024 Cybertruck
You start with the $50 plan, and once you've activated
Where do you find the $10/month for 10Gb plan?
I’ve looked on the website and don’t see it.
It
you
You can have the WIFi connected while driving. It's in the wifi settings menu.
MoabChris
Chris
San Diego, CA
2024 Cybertruck
The same thing happened to me. You can't find it on the website ($10/mo roam plan). Only once you've activated the mini... then you can change / down grade from the $50/mo plan.
Tesla Cybertruck Starlink mini roof mount power adapter cable (without having to run a cable into the bed) Screenshot_20250423_164343_Starlink
EXPTREVER
Trever
Folsom, CA
It
you
Oh got it, I must have missed it when I was driving with the starlink the other day. perhaps the wifi menu is only available in park? either way I'll update it. Thank you
linuxdrake
CyberBeast
I was able to put it in the back seat stuck to the glass roof just behind the driver. Bought a 10' Starlink to usb-c cable and power it off of one of the back seat usb-c jacks in the center console. Easy, secure, turns on/off with the truck.
The wire just drapes down and coils up in the seat back pocket of the driver's seat. Then the other end comes out of the pocket and plugs into the rear center console jack.
I still have to figure out how to have it ON when I'm outside the truck. Just haven't had the time...
The pic on upload/download readings is from just sitting in a parking lot.
The new pricing plan @ $10/mo for 10gb make it reasonable to not have to pause/unpause all the time.
What mount is that for the Mini?
Ivessm
Stew
PA, USA
linuxdrake
CyberBeast
conorearly
Conor
Kalamazoo, MI
Nurse Anesthetist
If you’re looking for a high quality mount designed with the CT in mind, e design and manufacture our own —whether you need a portable, permanent, or custom solution. Every mount is backed by our 100% satisfaction guarantee. Check them out here: https://contronx.com.
Happy to answer any questions—just let us know what you’re looking for!
Cyberspeed130
Dave
Tesla AWD Cybertruck
Product Development Engineer
The USB-C port in the Cybertruck has a max power of 65W, whereas the Starlink Mini needs 100W; have you seen any issues with your setup?
MoabChris
Chris
San Diego, CA
2024 Cybertruck
Nope. Works just fine, run mine all tire time. Just did the most recent firmware update using the starlink.... I've had zero issues.
Oden's Beast
Jupiter, Florida
2024 Cyberbeast
I paired my Starlink mini to my trucks WiFi once (only once). I did it because my WiFi was weak in my garage. Then quickly, I started to get warnings my data usage on the plan was nearly used up, It didn’t just use it for its updates, it was uploading my FSD data constantly. I ended up disconnecting it from the truck and now only use it connected to my IPad and phones (I put a new home access point in the garage just to get good signal there), I exclusively use home WIFI for my truck data now, as it quickly escalated my monthly Starlink bill. Just be careful when pairing to truck, as actual data usage connecting back to Tesla is intense! ?
