bosshog
roardog
canada
I agree . A lot of debris especially tree seeds can jam it up . I have had this problem on my other car near the window wipers . It needs to be flush . So I will definitely go for it even if I have to do the diy afterwards .
SASpursCT
Ryan
San Antonio
Cybertruck, MY
Commercial Real Estate
I'm sure there's a post about it somewhere. Can someone point me to a thread dealing with clearing the water stains that result from the water dripping down the back of the cab in the bed?
I picked up my CT on delivery day and was like WTF can we get that cleaned please and the delivery tech said it's impossible and I had to take it like that.
netcatz99
NJ
24 M3 LRAWD, 25 Cyberbeast
I wiped mine down w/ some Meguiar's Hyper Dressing. If you have hard water stains, then use a water/vinegar mixture or use an off the shelf hard water stain remover that's safe for plastic.
bosshog
roardog
canada
I mentioned to SC the new aero cover with the new seal and the fact I have unusual amount of water coming in. I got the below when I got it back. I need to see if I at least got the new aero. I still have a pretty good leak. Two SC trips ago I did have the gap. Gap fixed but now I have more slats and bars than I need and still leaks.
That bar . Andi they install that . Never seen that before … is that part of the fix .
koolio
Greater Boston, MA
Yes, but according to the service manual, the bar should be higher so as not to be in the middle of the window. It still blocks the window though (not that it really matters)
Limes2
Chicagoland
2025 Cybertruck AWD
I see no bar with the cover open or closed.
So the big thing is to make your service center fix the water, the VAULT should not be wet, put in a ticket and make them add the extra slat and weatherstripping as it is NOT in spec.
You will be fighting those stains and wet cargo forever, make sure they have the parts in stock before you drop the vehicle off for service, but make them fix the water leak.
Seribus
There's a new sail with a seal that is supposed to get swapped I think. I didn't get it. I still have my original sail with some sloppy glued gray foam. I need to get this fixed. Maybe third time is a charm at the SC.
koolio
Greater Boston, MA
Back in February, I asked about the new sail with the improved rubber seal but my SC wasn't aware of it at all. I showed them the picture that was posted on these forums but he said he'd never heard about it and there's nothing in the system. Maybe it's finally available to everyone?
I have a small leak by the rear window but it's not really bad, and really only when I go through the auto car wash. If it bothers me, I'll just apply the rubber seal myself (like in that guy's YT video).
Let us know if you have any luck, a "vault" that gets water in it is just a poorly sealed box, need these things waterproof, especially as these are now the premium version not the soft covers.
machmax
JP
Tampa, FL
‘24 CT (Non-FS), ‘15 Model S
After 5-1/2 mos. of wait for parts, my SC finally got ‘em and replaced the slat. Good work too, can hardly tell they did work on the cover. Before and after pics attached.
Tesla Cybertruck Tonneau cover gap issue fixed by Service Center under warranty IMG_8912
Tesla Cybertruck Tonneau cover gap issue fixed by Service Center under warranty IMG_9189
That looks 100% better, did you have leaking issues prior to the fix?
How did you get the SC to actually fix it and not say "in spec"?
koolio
Greater Boston, MA
Can you get a pic of the interior of the vault with it closed, to see if you have the bar blocking the rear window?
I’m just curious…
koolio
Greater Boston, MA
Just put a link to the service manual that shows how and when to add the extra slat.
