- Crissa
- Jul 8, 2020
- Santa Cruz
- 2014 Zero S, 2013 Mazda 3
Technically, Tesla already does this in their cars. There is a mechanical reduction gear.in the mid 20th century Volkswagen added a gear reduction at the wheel hub for the van. VW did this because they were still using a small air cooled 4 cylinder... gutless engine against the higher weight of the van. I wonder if the electric truck manufacturers would consider a similar concept of mechanical advantage to overcome the high energy cost of towing. Electronically switch to a gear reduction torque amplification to ease the drain on the batteries. It would reduce the acceleration. But blasting off the line while towing is a fool's affair. Then when the cruising speed was met, the gear reduction could be switched off.
I may still be stuck in the old thinking of a back yard mechanic.
