USB Music Playback
LoL Rick
Rick
Land O Lakes, FL
2014 S 85, 2018 3 Perf, CT AWD
Retired Software Developer
Has anyone gotten USB music to work? I have a folder of FLAC files that works fine on my Model S. I tried adding them to the USB stick in the glove drawer and nothing showed up. Then I tried them with a USB-C stick in the console formatted using exFAT and still nothing. Also tried the USB-C stick formatted as FAT32 and that didn't work either. Nothing I've tried makes USB show up as a music source.
Test the stick using MP3 files as those work on all Tesla models, also remove variables by formating a single USB drive to FAT32 and putting a couple MP3s in it.
If you get that to work you will need to partition a drive to hold music and another for your TeslaCam footage
CybrTrkNj
Edward
Mount Laurel, NJ
Lexus RX350, for a little longer..
Retired Network Engineer
Still waiting on VIN and CT, but this was a question I had too, if you can play music (mp3 files) from an installed usb-c flash drive. I have all of my music on one. Hopefully we get a good answer to this.
RandyS
Randy
I'm also very interested in USB mp3 music playback...On the screen menu, does it show the USB icon like in the lower right corner of the attached screen shot from my Model 3?
Now that I think about it, that may only be when it recognizes a valid USB stick (which it won't seem to do for you)...I hope you can get it working...
Tesla Cybertruck USB Music Playback TeslaUSBMenu
LoL Rick
Rick
Land O Lakes, FL
No it doesn't show up there either. I did a little research over on TMC and a thread there suggested it might show up with a reboot of the screen while the drive was plugged in. So I tried that and still no worky.
scottf200
Western NC
X; immed family 3 & Y
Not sure if this helps but does specify which USB and exFAT
Page 161
Playing Media from Devices
USB Flash Drives
Insert a flash drive into a front USB port (see USB-C
Ports on page 19). Touch Media Player > USB, then touch
the name of the desired folder. To play media from a
USB connection, Cybertruck recognizes flash drives only.
To play media from other types of devices (such as an
iPod), you must connect the device using Bluetooth (see
Bluetooth Connected Devices on page 161).
NOTE: Media Player supports USB flash drives with
exFAT formatting (NTFS is not currently supported).
NOTE: Use a USB port located at the front of the center
console. The USB connections at the rear of the console
are for charging only.
LoL Rick
Rick
Land O Lakes, FL
Not sure if this helps but does specifically locate to which one
Page 161
USB Flash Drives
Thanks for posting that. Yes, I tried it and the fact that it is in the owners manual is the only thing that gives me hope that it might work someday. Otherwise I would assume they just removed the feature.
FutureTruck
GA- USA
Tesla MX P, Lucid Air GT
Unlikely they removed such a popular feature that does not increase cost of the vehicle. Enough unpopular cuts were already made.
You might only be able to use the glovebox USB not the console ones.
MacOS instructions here.
BASICALLY [updated 15 March 2025]:
  1. Glovebox USB port only (you may want to purchase a larger stick)
  2. Must partition and format (GUID/exFAT) the USB stick
  3. Partition "TESLA":
    1. Folder "TeslaCam" (case-sensitive!)
  4. Partition "LIGHTSHOW":
    1. Folder "LightShow"
  5. Partition "MEDIA":
    1. Folder "Boombox"
    2. Folder "Music"
Optional: Folder "LicensePlate" in the root of any non-TeslaCam partition.
  • Up to 10 PNG images, each under 0.5 MB in size.
  • Filename under 32 characters with letters and numbers only.
  • Each PNG image should have a resolution of 420 x 200 pixels.
"Do I really need multiple partitions?" Apparently just adding folders on the primary partition next to "TeslaCam" will not work. Besides, the Sentry/TeslaCam partitions get written heavily, while the others are basically read-only, so it's best to keep them separate. The partition names do not matter, but the folder names are critical and case-sensitive.
Stop any camera recording (Park, and disable Sentry) before removing the USB stick to prevent data loss.
To replace your lock sound, place a file called "LockChime.wav" in the root folder of a USB partition. I used my "MEDIA" partition, I don't know if it will work on any of the others.
Then, in the Boombox screen, you should have a dropdown list for Lock Sounds that includes the choice "USB". Once you select it and test it, the USB drive itself can be removed since the sound is copied. To change to new custom sound, pick something else in the picklist before inserting the updated thumbdrive.
To get a reasonable volume, I used my PC to reduce it by 15db from a "normal" level. I also had to mix it down to mono to stay under the 1MB limit. It must be in WAV format. (OTA updates keep messing with this volume, so YMMV.)
TIP: When formatting on MacOS with Disk Utility, it cannot resize exFAT partitions. Therefore, create all the partitions as "Mac OS Extended", but change them to "exFAT" before clicking Apply.
Tesla Cybertruck USB Music Playback Screenshot 2024-07-19 at 7.43.04 AM
LoL Rick
Rick
Land O Lakes, FL
BASICALLY:
  2. Must partition and format (FAT/exFAT) the USB stick
  4. Partition "MEDIA":
    1. Folder "Boombox"
    2. Folder "LightShow"
    3. Folder "Music"
"Do I really need two partitions?" Apparently just adding folders on the primary partition next to "TeslaCam" will not work. Besides, the Sentry/TeslaCam partitions get written heavily, while the Media partition is basically read-only, so it's best to keep them separate.
Note I've not actually tried this yet...
Inspired by this, I took the USB-A drive out of my Model S and plugged it into the CT's glove drawer port. Lo and behold, it works! So now I just have to get an SSD and do some formatting.
LoL Rick
Rick
Land O Lakes, FL
Update. Just for kicks, I tried partitioning the USB stick that came with the truck and it worked. Sentry was able to record and USB music was also able to play. Then I clicked the "Format" button on the truck's screen to see if it would just reformat the TeslaCam partition. Nope, it gave an error and destroyed the whole drive. So don't do that. I repartitioned it on my PC and it is copying the music over now.
GuyV
Guy
St. Louis, MO
Could you post again exactly what works? ...the for dummies version please?
When I make 2 partitions all it seems to see is the Tesla one. It will give me USB if there is only one partition that only has music on it. ?
...and only from the glovebox USB-A, it sees nothing from the console USB-C port using a USB-C flash drive.
I use Tidal on my Model 3 (and now also on my Cybertruck). The only way to get higher than MP3 sound quality when not connected to Wi-Fi is to download your Tidal tunes. When I entered my Tidal username and password, all my existing music appeared. But to play in Hi-Fi, you need to download them to the vehicle. Tidal makes this dead simple, just select the playlist and click download. If you do it when connected to Wi-Fi it starts downloading immediately, if connected to cellular it ques it up for download next time your vehicle is connected to Wi-Fi.
I haven't checked yet whether it downloads music to system memory or to the 128 GB stick in the glovebox.
GuyV
Guy
St. Louis, MO
That would be very interesting to know.
