PungoteagueDave
- David
- Mar 2, 2025
- Boynton Beach
- â25 Tesla Cybertruck, â26 Tesla MY Launch, â13 Porsche C4S, â26 BMW R1300 GSA
- retired
Stick with your must-own narrative all you want. The engineers who took it apart at Munro, who had lauded the exoskeleton as revolutionary, concluded that the CT DOES NOT HAVE AN EXOSKELETON. Calling stressed panels, whether glued, screwed, or welded in place, a per-se definition of an exoskeleton may be necessary for your story, but it just isnât so. EVERY unit-body vehicle uses the exterior panels as stressed members, critical to the strength and integrity of the body. I did not say the stainless panels werenât stressed members or that they had nothing to do with body integrity, or that they are particularly thin - thatâs your defensive fanboism showing.Incorrect. Structural adhesive is found on the structural elements of every modern car. Calling it "glue" does not change that fact, nor does it mean the Exoskeleton is not structural. Lars (the Head of Vehicle Engineering at Tesla) has made it clear that the sail panels are structural. Otherwise they would have been much thinner and lighter.
While it's obvious that the stainless steel does not carry the same percentage of structural strength as originally planned, this design is actually lighter than it would have been had they used the full 3.0 mm thick panels. Because the other chassis components are shaped and placed specifically where needed to carry the load. The panels just add the last 10-20% of chassis rigidity and payload capacity. Without those panels being structural, the truck would not exhibit such crisp handling performance. This is why people say it handles like a big sports car (because it has more body rigidity than million dollar sports cars). I've driven my Cybertruck on narrow, twisty one lane paved mountain roads with 2400 lbs. of firewood and tools in the back and the handling was still crisp and controllable. No body on frame truck can do that (and even the chassis of other unibody trucks like the Avalanche are not nearly as rigid).
Except the efficiency is not almost the same, the dual motor Cybertruck is around 20% more efficient than most dual motor Silverado's. If you subtract the battery weight from each brand of truck, the Cybertruck is about 1,000 lbs. lighter and has a higher payload capacity. That's due to it's better engineering and using the thick body panels as structural elements.
I know you like to shit on the Cybertruck, but please avoid using inaccurate comparisons and statements when trying to compare the two. If what you said were true, there would be a 340 mile version that weighed the same or less than the Cybertruck. But it's not even close.
I did not denigrate the fact that the panels are in most part, glued on - I acknowledged that industrial adhesives are perfectly legit on stressed members - in fact many supercar frame structures are almost entirely glued together, with supplemental rivets. What I said, correctly, is that instead of using the exterior panels as the PRIMARY modality for body structure as originally planned, (hence the name exoskeleton), the PRIMARY structural skeleton for the CT is the underlying super-strong steel structure on which the exterior panels are hung using adhesives.
The ORIGINAL CT design did NOT have that separate internal steel structure. Tesla intended to use the bent stainless steel external structure as the primary strength for the body, actually lightening the overall finished body. The intention was to integrate teh exterior panels directly with the frame castings. Instead the underlying steel skeleton is attached to the castings, and the stainless steel is mostly glued together the steel structure, adding an entire unplanned layer and concomitant weight. What we now have is fairly standard unit-body construction, except heavier than most lightweight steel or aluminum bodies due to the nonstandard castings and added steel layer, plus this thicker-than-standard heavy stainless steel.
If you know anything about the delays and the history of the CTâs engineering, you will know that the engineers had to restart nearly from scratch partway through the final design process. In addition to downsizing the truck about 20% from its original specs, they reached the conclusion that the test bending process for the stainless steel wasnât working (Elon proclaimed that it was, for him, a hard lesson in metallurgy), and if they proceeded, the entire program could fail. They fell back on a solution that required much less stainless panel bending, while keeping the look, but abandoning the exoskeleton concept.
There is no question that the CT has no exoskeleton. Stick with your narrative if you must - but it is only necessary to look at the actual structural skeleton underlying the stainless panels to know THAT is the current CT skeleton - nothing âExoâ about it - it is entirely âInoâ. It was not originally intended to be there, but was required by the midstream rework due to assembly and fabrication technical limitations. These are the facts, but I do understand why some continue to stick with the exo-narrative.
