anionic1
- Michael
- Apr 30, 2021
- California
- Cybertruck
- Estimator
It will have struts. It will have internal stamped body components. You can see them on the CT website and in the patents. People act like the exterior stainless panels you see are it. The entire body. That will definitely not be the case. The internal body framing will be lighter but it will be there none the less. 2mm would seem more than sufficient Partly one risk of going thinner without stamping is that you can get oil canning in plate or coil steel and the stiffeners required to mitigate that would likely cost just as much as going thicker on the steel.The 1976 VW Beetle had 22 gauge (0.70 mm) sheet metal. The cybertruck doesn't have sheet metal over "struts" or whatever the supporting structure is called in the vehicle industry. It needs the additional skin thickness in order to meet specs.
