Any 500mi range updates?
Rozonoe
Michel
Hawkesbury Ontario
2018 Tesla M3 LR75, Cybertruck Dual FSD
Real Estate
Range is king. We have treaded over this territory enough times ... fast charge times 'are' important, but as @Ogre and @TBONO mentioned, the large the range the more useful the truck will be and the better the charging rate. Just imagine pulling up to a 1MW charger and being able to charge at that rate for even 10 minutes!
What about vehicle to home or grid, better have a big pack unless Tesla remove the feature.
RVAC
Ahh, right.
Thanks. I had to drop from his Patreon because he was sharing some bigoted memes.
Anyhow, my point was there's no reason to think Panasonic won't have the same troubles Tesla did in making the 4680, and have to take time to learn how to apply the chemistry to a larger cell. See 8:30 in the video.
They use a wet process for the anode and cathode so they won't encounter the same troubles as Tesla, should be the same as their other cells chemistry wise. Anyway if Panasonic is able to produce higher energy density cells earlier than Tesla that's good not a negative.
Rozonoe
Michel
Hawkesbury Ontario
Real Estate
That's not true. The trimotor page displayed it the same way the single motor page displayed it.
https://images.app.goo.gl/V579ya1XRqTD6bCx7
That wasn't the only place 500+ was mentioned. And didn't always say "up to".
https://images.app.goo.gl/FHz3heD7iLeZZqSQ6
Tesla has sent mixed messages about this issue from the start, because stating "up to" a number gives a ceiling, adding the + afterwards makes it confusing because the + isn't defined.
Like the linked photo. That photo tells me I'll get at least 500 miles of range (assumed based on some level of epa standard...driving 55, not towing, not fully loaded, but under ideal circumstances I could expect at least 500 miles).
And then there were those gui pics that showed a 610 number. Some (not me) think that number was also an indication of range.
Lawyer language for future lawsuit.
No-mo-ice
Battle Ground, WA
Raptor
Aerospace Engineering
I must confess, I don’t use my truck for hauling that much. I hunt and fish, so I fill up the truck bed when I do that, but I never feel comfortable that my gear won’t be stolen because I detest truck caps, crawling back inside to grab something…. I’m too old to be doing that. I like the CT because of the rolling vault, and the fact that it can tilt down. Other than that, I drive my truck around on roads, and basically the bed of the truck is like an empty suitcase. I don’t think I’m alone there. I enjoy trucks, and I when I need to do truck type things in it, I’m glad to have it. Apparently my family likes it too because whenever they move… they call me first.
intimidator
TJ
Alexandria, VA
2023 Ford Lariat Lightning
Who needs a long range battery when a rapid charge battery is a better solution? It would be smaller and lighter.
Wish it was that simple.
Someday it might be, but it isn't yet.
Battery management is part of the issue. If you only have 350 miles of max range, for example, and you never charge more than 80%, and never go below 10%, it cuts the range quite a bit.
And in my opinion, and my opinion only, EVs have to be designed with the assumption the customer WONT be able to charge at home. Something like 55-60% of the US population does not have the option of charging at home. We can't build EVs just for the 40%ers.
intimidator
TJ
Alexandria, VA
Ding Ding Ding. We have a winner.
Exactly. 300 miles might suffice for some people, but for many it won't. Especially if it is your only vehicle. Or you live in an apartment, or condo, or townhome, or rental property. You will not be charging at home.
300 mile EV trucks may be fine for 30% of the population? (or pick your own #).
Tesla doesn’t support V2G and has been vocal about not doing it … so far.
charliemagpie
Charlie
CybrBEAST
In any case, that Solar Vault is for me the 'Game Charger' especially when in Outback Australia
The funny thing is, my point was fixated on driving a month without having to charge. After posting that I had calculated 15 extra per week... it should have been per day.
The 60 extra miles, should read 420 or whatever sun it gets. It is significant.
We haven’t heard a peep about that for ages but it can’t hurt to hope. Game changer? That sounds big.
