Charging cars at home at night is not the way to go, Stanford study finds
Newton
Newton
East Bay Area, CA
Whats the TLDR? I dont want to read it.
seems counterintuitive not to charge at night when no1 else is using energy. im guessing the argument is that we will have to keep more fossil fuel plants running since solar doesnt work at night.
Simply; incentivize EV's to charge from solar during the day whilst parked at work. Less fossils that way. Thread title is just provocative.
firsttruck
mx
It is always about supply and demand. Both volumes and prices/costs of each side.
These situations are dynamic. There is nothing guaranteeing a permanent state of balance over short or long periods of times.
Today in most place there is excess supply at night so EV charging is generally cheaper at night.
In the future the balance of volumes & prices could be different.
With solar costs continuing to decline and volume of solar greatly increasing it is possible the whole situation could flip and we need people to move more usage to sunny times of day.
Elon & other scientists for several years now have talked about that with today's technology it is already possible for U.S. to power all electric and transportation needs using only renewables. We just need to build the infrastructure. No need to wait for some future tech breakthroughs.
With enough rooftop solar and grid based solar it is entirely possible that charging EVs batteries during the day is cheaper than at night.
The TLDR is that power companies will need to adjust pricing based on actual supply of power over time. The assumption seems to be that “peak” hours and pricing won’t change over the next 20 years.
This assumption pretty much undermines the whole article. As the supply of solar power comes online, peak power rates will shift and consumers will adapt. For many people this will work out very well, solar production in the summer time is usually quite high at 5-6 pm when commuters get home from work.
That’s without businesses offering solar charging which they totally should.
charliemagpie
Charlie
CybrBEAST
It would be great if Tony Seba was to make another presentation... a sort of current state of affairs, and where things might land in 5 and in 10 years from now.
Um that assertion relies on false premises.
Solar doesn't have any ability to power peak load directly when people come home at 5-6pm.
This is what total insolation looks like for LA in the best summer day, and shows clearly that the sun itself , physically sets long before peak does. Winter solar is nowhere near peak. Note this is only available "IF": your PV array is tracking, or facing West, and you don't have low cloud formation from sunset induced temperature condensation. If it faces West you loose peak at midday an a lot of generation hours (bulging the red curve to the right and reducing the area/energy), and even more in winter. You also have to have roof space facing this direction if mounted on household. It is not a viable way to install solar in any case, and I doubt there is a single installer that would recommend it.
Tesla Cybertruck Charging cars at home at night is not the way to go, Stanford study finds 1665030301820
The orientation changes it to:
Tesla Cybertruck Charging cars at home at night is not the way to go, Stanford study finds main
Note the red line is only at 30% of panel rating by 3:30pm and 10% by 5pm, and suffers a 28% reduction in solar hours per year because of the west orientation to do it. South facing degrades even earlier in the day so wouldn't help peak reduction.
You either have to change the peak, by forcing people to stop work and school earlier and send them home, or add significant storage to buffer the peak, or get them a bunch of scheduled appliances. Either way peak must change, because you can't change solar times, unless you change time.
Tesla Cybertruck Charging cars at home at night is not the way to go, Stanford study finds 61c4d1553ddaa.image
CAISO are actually predicting a shift of the peak to later and not earlier putting it even further out of reach of sunlight hours.
All this comes back to what was posted on here a while back on this thread, and that is the ToU is a human activity scheduling problem that could be fixed by offsetting business and school hours, which would also solve traffic too.
But in the meantime, EV's should be charged directly from solar during the daytime, if they did they could even bring energy home at night via V2H and not only offset the households peak with EV capacity, but could also feed into the grid for others as well.
Just put solar at work and you wouldn't even add network load at all by introducing EVs.
My “Assertion“ is: “The TLDR is that power companies will need to adjust pricing based on actual supply of power over time.” Which is true regardless of whether my exact example is accurate or not.
Your long winded correction of my example might be interesting if it remotely resembled the ground truth.
Exactly which part of California are you suggesting will be producing nearly zero solar power between 5 and 6pm in the Summer Time? If you can’t find abundant solar power at 5pm on a California Summer Day, you probably have an extra hole in your head.
Wow nice!
You obviously know nothing about solar inclination.
At least my head can see the light, with yours it seems to go straight through. ?
Maximum solar output for a fixed PV module only happens on two times in a year.
Everything else is less.
Tesla Cybertruck Charging cars at home at night is not the way to go, Stanford study finds feature-inclinaison
Time to get your measuring stick out!
And as for TLDR: the price is not created by sheer utility "will" but from cost of generation and distribution, and unless it's more than 4-10x the price will unlikely impact ToU and when people get home to use power. So if solar can't do it, and you can't tell the wind to blow, from what then?
Once you get that hole fixed in your roof get back to me with data and examples. Thx.
You obviously know nothing about California.
Or remotely give a shit about the actual point.
Brilliant rebuttal. Absolutely changed my mind!
Only confirms that California has long left planetary dynamics and is now floating in their own subspace of made up facts. ?
Article says specifically, if you read it at all:
In a little over a decade, they found, rapid EV growth alone could increase peak electricity demand by up to 25%, assuming a continued dominance of residential, nighttime charging.
To limit the high costs of all that new capacity for generating and storing electricity, the researchers say, drivers should move to daytime charging at work or public charging stations, which would also reduce greenhouse gas emissions.
“We were able to show that with less home charging and more daytime charging, the Western U.S. would need less generating capacity and storage, and it would not waste as much solar and wind power,”
“The findings from this paper have two profound implications: the first is that the price signals are not aligned with what would be best for the grid – and for ratepayers. The second is that it calls for considering investments in a charging infrastructure for where people work,”
Feel free to take a deep breath (its still free you know) and present some facts/links/quotes or demonstrate how it is so, instead of attacking me. Thx.
MiguelAznar
Miguel
Cybertruck 3-motor
I enjoy reading the thoughtful posts from both JBee and Ogre, so it pains me to see the vitriol. Let’s get back to your brilliant insights and analyses ?
I think there might be some residual belief, since a resent discussion on what actually is the CT exoskeleton, that my conversation is just meant to be contrary, rather than trying to see through the fog of ambiguity to gain resolution.
Old Pro
Bob
I own a 2006 Toyota Tacoma and 2018 Tesla Model 3,
The move to electric vehicles will result in large costs for generating, transmitting, and storing more power. Shifting current EV charging from home to work and night to day could cut costs and help the grid, according to a new Stanford study.
By Mark Golden
The vast majority of electric vehicle owners charge their cars at home in the evening or overnight. We’re doing it wrong, according to a new Stanford study.
If the common charging of electric vehicles at home in the evening or overnight shifts to daytime at work as more cars go electric, then that would restrain extra costs for electricity systems, according to a new Stanford University study. (Image credit: Amy Adams)
In March, the research team published a paper on a model they created for charging demand that can be applied to an array of populations and other factors. In the new study, published Sept. 22 in Nature Energy, they applied their model to the whole of the Western United States and examined the stress the region’s electric grid will come under by 2035 from growing EV ownership. In a little over a decade, they found, rapid EV growth alone could increase peak electricity demand by up to 25%, assuming a continued dominance of residential, nighttime charging.
To limit the high costs of all that new capacity for generating and storing electricity, the researchers say, drivers should move to daytime charging at work or public charging stations, which would also reduce greenhouse gas emissions. This finding has policy and investment implications for the region and its utilities, especially since California moved in late August to ban sales of gasoline-powered cars and light trucks starting in 2035.
“We encourage policymakers to consider utility rates that encourage day charging and incentivize investment in charging infrastructure to shift drivers from home to work for charging,” said the study’s co-senior author, Ram Rajagopal, an associate professor of civil and environmental engineering at Stanford.
In February, cumulative sales of EVs in California reached one million, accounting for about 6% of cars and light trucks. The state has targeted five million EVs on the road by 2030. When the penetration hits 30% to 40% of cars on the road, the grid will experience significant stress without major investments and changes in charging habits, said Rajagopal. Building that infrastructure requires significant lead time and cannot be done overnight.
“We considered the entire Western U.S. region, because California depends heavily on electricity imports from the other Western states. EV charging plus all other electricity uses have consequences for the whole Western region given the interconnected nature of our electric grid,” said Siobhan Powell, lead author of the March study and the new one.
“We were able to show that with less home charging and more daytime charging, the Western U.S. would need less generating capacity and storage, and it would not waste as much solar and wind power,” said Powell, mechanical engineering PhD ’22.
“And it’s not just California and Western states. All states may need to rethink electricity pricing structures as their EV charging needs increase and their grid changes,” added Powell, who recently took a postdoctoral research position at ETH Zurich.
Once 50% of cars on the road are powered by electricity in the Western U.S. – of which about half the population lives in California – more than 5.4 gigawatts of energy storage would be needed if charging habits follow their current course. That’s the capacity equivalent of 5 large nuclear power reactors. A big shift to charging at work instead of home would reduce the storage needed for EVs to 4.2 gigawatts.
Changing incentives
Current time-of-use rates encourage consumers to switch electricity use to nighttime whenever possible, like running the dishwasher and charging EVs. This rate structure reflects the time before significant solar and wind power supplies when demand threatened to exceed supply during the day, especially late afternoons in the summer.
Today, California has excess electricity during late mornings and early afternoons, thanks mainly to its solar capacity. If most EVs were to charge during these times, then the cheap power would be used instead of wasted. Alternatively, if most EVs continue to charge at night, then the state will need to build more generators – likely powered by natural gas – or expensive energy storage on a large scale. Electricity going first to a huge battery and then to an EV battery loses power from the extra stop.
At the local level, if a third of homes in a neighborhood have EVs and most of the owners continue to set charging to start at 11 p.m. or whenever electricity rates drop, the local grid could become unstable.
“The findings from this paper have two profound implications: the first is that the price signals are not aligned with what would be best for the grid – and for ratepayers. The second is that it calls for considering investments in a charging infrastructure for where people work,” said Ines Azevedo, the new paper’s other co-senior author and associate professor of energy science and engineering in the Stanford Doerr School of Sustainability, which opened on Sept. 1.
“We need to move quickly toward decarbonizing the transportation sector, which accounts for the bulk of emissions in California,” Azevedo continued. “This work provides insight on how to get there. Let’s ensure that we pursue policies and investment strategies that allow us to do so in a way that is sustainable.”
Another issue with electricity pricing design is charging commercial and industrial customers big fees based on their peak electricity use. This can disincentivize employers from installing chargers, especially once half or more of their employees have EVs. The research team compared several scenarios of charging infrastructure availability, along with several different residential time-of-use rates and commercial demand charges. Some rate changes made the situation at the grid level worse, while others improved it. Nevertheless, a scenario of having charging infrastructure that encourages more daytime charging and less home charging provided the biggest benefits, the study found.
Rajagopal and Azevedo are also co-directors of the Bits & Watts Initiative at Stanford’s Precourt Institute for Energy. Other co-authors of this study are Gustavo Cezar, PhD student and a staff engineer at Stanford’s SLAC National Accelerator Laboratory; and Liang Min, managing director of the Bits & Watts Initiative.
This work was funded by the California Energy Commission, the National Science Foundation, and the Bits & Watts Initiative with support from Volkswagen.
To read all stories about Stanford science, subscribe to the biweekly Stanford Science Digest.
-30-
Tesla Cybertruck Charging cars at home at night is not the way to go, Stanford study finds {filename}
https://news.stanford.edu/press-releases/2022/09/22/charging-cars-honight-not-way-go/
We have a 2018 Tesla Model 3. Tesla Solar panels at home, during the summer when the output of the panels are optimum, we have been charging during the day. We consider ourselves lucky!
ldjessee
Lloyd
Indiana, USA
