For those with the S92 Camera Mirror
Sorry guys. Happy to help troubleshoot with you or even talk through it with you on the phone/dm/share pics etc, but I don’t really want to write an instruction manual for these guys. They need to step up.
They didn’t exactly do me any favors that make me want to do their job for them.
Hope you understand
pypypy
P
Georgetown
@Tesstudio can we please get some instructions on how to plug this wire in?
whether the 1st or 2nd harness, it's just plug and play. regarding the 2nd harness, the power source by the driver side mirror only fits in one of the the plugs and the sensor by the passage door also only fit in one plug. good luck and hope you don't get any errors.
4Everhard
Ok no need to get instructions from anyone other than @Tesstudio but can those who installed the harness explain what they did? No risk or liability just a simple statement of what they did
So. I started with exposure. There are basically three fields. One is under the mirror. Let’s call this field 3. The mirror has to come off for you to remove the cover (bummer), so I started by taking out the screw. I think it was a t25? Not sure but it was a fairly common tesla size. Right in the middle of the mount. Heads up, very easy to drop that screw and lose it. Once you get the cover off just let it hang there. Dont unplug anything. The little plug on the inside of this housing closest to the driver side is where you will insert part of the new harness for power.
The other important field is the door area on the passenger side. Let’s call this field 1.
I took the whole rubber gasket seal off but it’s probably easier to just peel it back just to the end of the lower trim piece you are trying to get out. Then you take off the little square trim panel right under the passenger side mirror on the dash side. Pull back the trim piece that traverses down and towards the “cybertruck” door plate. Pull down the magnetic cover under the glovebox and then peel back the trim carpet trim from the door towards the center console. The harness plugs in in two places here. One is to the computer which is further forward and one to another plug connected right by the door.
Field 2 is the space between these two. Basically the headliner and pillar. I pulled my headliner largely down in front but not sure this was necessary if I had fished the wire out at one spot and just followed it until it was all outside the headliner. My old harness wasn’t attached in any way there by the installer who did the work. It was just laying in the headliner.
Anyway now you figure, what’s staying in the car? cameras and mirror, so find where the harness connects to these and unplug. In my case this was just sitting in the headliner (zone 2) also. It’s a round little plug. Unplug it and plug in the new harness with the only other same looking round plug.
now start working your way back towards zone 1. Remove old harness and replace with new harness as you go along. Just lay it in the edge of the headliner and tuck it in every couple of inches so it stays up there.
Once you’re all the way back to the passenger footwell (zone 1 ) unplug the old harness form the connectors so it’s completely free for removal and plug in the new harness. Connectors are unique and therefore location is self explanatory.
now. Go back to the mirror area (zone 3) . On that end of the new harness is a little power connector. It bridges into that little power connector attached to the inside of the FSD camera cover hanging down. Unplug it, and plug in the new s92 harness bridge into it.
Reset the system. I did a two finger salute reset at this point.
Start the car. Actually start it like you’re putting it in drive (press brake pedal) . It will take several seconds but your mirror should power up and work.
Tuck away the wires and reassemble your truck.
Please feel free to reach out if I can help otherwise. I’m certainly no expert but I was SO frustrated with this thing I’m willing to spend some time helping you avoid the same feeling.
Tesstudio
Tesstudio
www.tesstudio.com
Hardest part seems to be getting the new harness!! ?
For any products purchased from us, we will provide them, and we will also offer customer service via instant messaging.
4Everhard
I'm sorry I have to return this mirror. I waited for your new harness but the mirror now doesn't even power on. I cannot wait around any longer. As stated in my first email, the mirror was not powering on correctly every few times. Now it's not working at all. Please let me know process to return for a refund.
Tesstudio
Tesstudio
www.tesstudio.com
During our first interaction, I tried to ask you for the order number, but you didn't provide it. However, in order to resolve your issue, I immediately sent you our customer service WhatsApp. You can still contact our customer service on WhatsApp to resolve your problem, but you must first provide our customer service with your order number. This is the key to solving the problem. Thank you.
4Everhard
That is not correct. See below where I clearly added my order number. I have sent it again.
Tesla Cybertruck For those with the S92 Camera Mirror Screenshot_20250617_054718_WhatsA
Tesstudio
Tesstudio
www.tesstudio.com
Alright, I will check with our customer service and have them address your needs.
