Setok
Finland
Land Rover Defender
You're out of the region, it's gonna have hacky solutions if you want the original.
Nothing has actually been stated by Tesla in that regard. But it would be awfully nice if they did formally confirm no CT for outside US (at least now). Then again Ford is bringing the Lightning to Europe, so Tesla can't wait forever. At the moment Europe is wide open for utility EVs, especially offroad capable. Vans, however, have started to appear.
BigAl
Al
CyberTruck
Can someone in the know explain the front wheel "flaps" I guess it must be for the airflow, but I've never seen a car/truck use it... ANYONE????
Paradox
2023 Escalade ESV Platinum, CT TriMotor FSD
I thought it’s for airflow as well. This isn’t my Escalade in the pic, it’s a pic I found online, but my Escalade has them to a lesser degree. Guessing Tahoes, Suburbans and Yukons have them as well.
Tesla Cybertruck Franz breaks out Cybertruck for Cars And Coffee @ Petersen! Driving & closeup! Tonneau! IMG_3996
Edit: Spelling
yea, for aerodynamics
especially with but not just in BEVs, the wheel/wells are a significant source of drag
pretty much all modern trucks have a version of these, though sometimes rather than being merely 'flaps' in front of only the wheel, its an entire lower front skirt
BEVs just benefit moar from even moar
If the L-Track on the bed sidewalls has a standard 1 inch center-to-center mounting point spacing, it serves as a good way to measure the bed length; we just have to extrapolate the additional length beyond the ends of the L-Track. I count 61 mounting points total, so the L-Track length between the two end mounting points is 60 inches. I estimate 2 inches from the face of the cab overhang to the first mounting point at the front end of the L-track, and 4 inches from the inside surface of the tailgate to the last mounting point at the back end of the track. That's a total length of 5 feet, 6 inches for that dimension of the bed, agreeing with most of the other estimates I've seen.
I had previously made a similar calculation over here, but without a good side-on view for using pixel measurement tool across the length of the bed
this isn't the best side-on view, but still accounting for some distortion etc. and the earlier OP work, I put the measurement tool to this new bed photo and assuming 1" L-track center spacing - also arrive at around 5.5' for that dimension of the bed, give or take
show work in the other thread:
In the slide deck above I used the L-track mounting point spacing, assumed to be 1" as usual, for some relative size estimates/confirmation, eg.:
Now with this recent, more square-on, photo of the entire bed length, the same 1" spacing assumption can be used to guestimate some other surrounding bed measurements (with some minimal distortion in this lens)
First, based on the 1" spacing assumption, the L-track has 61 holes total, making the center-to-center of the L-track's outermost holes a known 61"
in order to account for both lens and perspective distortion (this photo is taken at enough of an angle that it would materially impact - making area near tailage appear elongated compared to compression at the bulkhead), I re-calibrated my measurement tool at either end of the photo (e.g., so the 1" standard near the tailgate was used only to measure items near the tailgate, and vice-versa for near the bulkhead)
the main measurements from the tailgate to the bulkhead sill encroachment over bed floor:
  • L-track total (center-to-center of outermost holes) = 61" [assumed]
  • Tailgate-side distance from nearest center of hole to ~tailgate = 5"
  • Bulkehead-side distance from nearest center hole to window sill = 2.5"
  • TOTAL: ~68" (5'8") from tailgate to bulkhead sill encroachment over bed floor
For fun, and to cross-measure accounting for distortion along the length, I measured from the L-track's outermost holes (presumed 61") and took the resulting pixel measurement distortion error factor and factored it into an overall length measure and got 68.46" - so pretty consistent across both methodologies.
In the last photo above, note that I took the opportunity to also get a measure of the hardware width, which came in at ~5.28"
Which is consistent with my earlier guestimates from the OP:
And all these measurements, are consistent with my earlier estimates of:
Which altogether reflected estimates of:
  • the total bed depth at floor of right at 6' give-or-take an inch
  • bed depth between bulkhead sill and tailgate of ~5'6"
  • total encroachment of the over-window eave of ~10-12" (meaning the bed aperture is roughly/just over 5' give or take an inch or two)
Which for the more visual among us would result in overall bed lengths at different height intervals of around (give or take an inch or two):
What's the chances of the newer CT being anywhere near the Peterson when we visit it tomorrow? :cry:
charliemagpie
Charlie
CybrBEAST
Zero. Thats how the world works. It will be there after tomorrow. :ROFLMAO:
damnitjim
Bones
Massachusetts
Audi Q7 S-Line, Audi Q5 PHEV S-Line, CT3 Pre-Order
AV Field Engineer
This is just my guess until we find out otherwise:
because of LED flicker in the video, you don’t get to see a consistent light pattern on the lights.
What about the top light bar? I thought they were keeping that but haven't seen since OG proto
