Help! Power out and PowerShare won’t initiate feed to house from Cybertruck
CYBROSKI
Chris
Cybertruck Dual Motor Foundation Series, X, Y
Pilot
Looking for some help from the Tesla Community regarding Cybertruck PowerShare. Currently power is out and I plugged in my Cybertruck with a tested and functional PowerShare system. No power is being provided to the house and I’m just getting the “Unable to Charge-Charge Station Not Powered” alert. Any ideas? Pretty disappointed. Went through lots of $ and hassle to get the system installed and now it does nothing and no Tesla support can help. No help from Charging or Powerwall Customer service (closed) or Roadside assistance.
Tesla Cybertruck Help! Power out and PowerShare won’t initiate feed to house from Cybertruck IMG_5349
Tesla Cybertruck Help! Power out and PowerShare won’t initiate feed to house from Cybertruck IMG_5350
Guylouis
Guy
F.S. CyberBeast, XP, YP, 3P
Double scroll wheel reset
Hold both scroll buttons on your steering wheel until the screen resets
CYBROSKI
Chris
Pilot
Hi, I tried that as a first action and no change to the situation. I appreciate the reply. Cheers!
CYBROSKI
Chris
Pilot
I’m thinking that it may be due to a cold battery, which is cited as a reason in the owners manual that the PowerShare may stop. Initiated a Precondition scheduled for 10 minutes from now to try and get the battery to heat up. The UI isn’t helpful as it doesn’t tell you that this could be preventing PowerShare from working. It should know that there is no utility power and the Cybertruck is plugged into the wall connector/Powershare system with the PowerShare button enabled.
CYBROSKI
Chris
Pilot
CYBROSKI
Chris
Pilot
I don’t have a UPS so no internets right now for the PowerShare system.
CYBROSKI
Chris
Pilot
I think you and I have different definitions of the word “cold” ?
Haha, I just have the snowflake icon. Definitely not actually that cold.
Yeah, “no data” means it’s not network-connected, unsurprising in a power outage.
Even with PowerShare, I have UPSes on things like my internet devices that take several minutes to restart.
The WiFi should not be necessary for PowerShare to activate. Maybe you could try flipping the UWC breaker off/on but IDK if that’s any different from unplugging the truck.
You could always try a vehicle reboot:
  1. Shift into Park.
  2. On the touchscreen, touch Controls > Safety > Power Off.
  3. Wait for at least two minutes without interacting with the vehicle. Do not open the doors, touch the brake pedal, touch the touchscreen, etc.
  4. After two minutes, press the brake pedal or open the door to wake the vehicle
https://service.tesla.com/docs/Publ...UID-76C3CAB5-8F3F-4F0A-93F4-966DB3E67FEA.html
RN1127
WA
FS AWD
Happened to me as well, went disable power share and re-enable from car screen solved the problem for me. You can give it a try
CYBROSKI
Chris
Pilot
Did you also have the “Unable to Charge-Charge Station Not Powered” alert? I’ve tried to turn the PowerShare on and off a bunch of times. Any trick to the timing or did you just turn off and then back on once? Thank you for the reply!
Redfire
Atlanta, ga
Cyber Beast
Possible tripped breaker in the power share panel?
smcnaughton829
Stephen
New York
Model 3, Model X plaid, S, CB
Pilot
I don’t have the PowerShare like you have on my MCU. I got my gateway installed last week. How long before I get the update to make everything work?
