If you could request three factory add-ons, what would they be?
Bitmaster
Scott
Oregon
Electrical Engineer
1. Starlink
2. Speedo and other gauges in front of steering wheel
3. extra range
Also like winch option and especially like the real spare, mounted on a swingaway behind the tailgate.
Love option 2. I'm not a fan of the minimalist styling.
TK0384
Dan
Dallas
Scion xB
1. Antigrav hover mode (c'mon Elon we know you're working on this)
2. Railgun (hey maybe Russia/China will invade)
3. Solar panels for when the power grid fails
This is true. It is much more efficient to coast.
I would certainly prefer the option.
Personally, highway driving would be full coast with regen only used to maintain speed on downhills, town driving would be 1 foot driving.
bootcoder
Hunter
2000 Ford Excursion
Software Eng
1. Dual charging ports
Port on both sides, preferably larger packs each port could charge a portion of the pack independently or function normally under a single plug in from either. Additionally it would be fabulous those ports could send/receive power from a towed battery like say an AirStream with a M3 pack in the floorboards.
2. Work table style powered frunk
Wanted this prior to Lightning reveal. Frunk should open along with grill to a useable flat space with a lip on the leading edge to prevent roll away of things. Lots of power and LED lighting.
3. Multiple undercarriage camera's
Think rock crawler visibility, you could see each wheel at nearly ground level
4. (/S) Electro Defense Mode
Think Sentry mode with bite. When engaged the exterior steel could be electrified on contact to..... deter break-ins
charliemagpie
Charlie
CybrBEAST
Tesla Cybertruck If you could request three factory add-ons, what would they be? 1645840826161
The bottom of the Cybertruck frunk will likely be a lot lower than the Ford. Likely way too low to act as a work surface. It would be nice regardless to have it open along the bottom so you don’t have to lift things over the lip of the frunk to get them in or out.
Musk was talking about Wi-Fi cameras for reversing. I’m hoping there will be options to add multiple remote cameras wherever you want. For that matter, I mentioned in the App Store thread, the ability to add arbitrary BlueTooth or Wi-Fi accessories.
But I don't like one-pedal driving. And mixing regen on the accelerator has been determined to be less efficient Wh/mi.
ave to
What you will find in practice is that efficiency is not ruled by whether regen is on the go pedal or the stop pedal but how the driver uses it. I coast all the time in my Model 3 simply by applying the throttle to the appropriate position.
I would be interesting in seeing the study that "determined" regen on the accelerator reduced efficiency It could be a test designed to make Tesla's look inferior. In any case, the results of any test of this nature would depend upon the skill of the drivers and how long they had been using one pedal driving. It wouldn't surprise me if ham-footed drivers that used the accelerator as an on-off switch might not return very good efficiency.
Friday
Grover's Mill, NJ
1) Moisture harvester for clean drinking water.
2) Starlink (satcom)
3) Incinolet outlet or a space ready to install one in the vault.
ave to
It's unrelated to Tesla: Zero Motorcycles allow you to change these settings, and since the motorcycle already has limited range, guys have tested the heck out of it.
It's like the old saw about cruise control being more energy efficient to hold a steady speed: A human will wobble a little, so you can't hold exactly the right spot over time so you end up shifting your grip (or step). Modern cruise control can do it much faster, in smaller increments.
Regen just increases those differences, so one-pedal driving over the long run is slightly less efficient than only activating regen when you intend to slow down more than a coast.
