My CT starts shivering around 76miles/hour. how is yours?
Cybaba
Coco
Santa Clara
Land Cruiser
They're not your drivetrain.
The three motors in the Cybertruck's DbW (Drive-by-Wire) system are separate from the main drivetrain motors.
* Main drivetrain motors - AWD: These are the electric motors responsible for propelling the Cybertruck forward and backward.
* DbW system motors: These are three small electric motors specifically dedicated to the DbW system. They are not involved in directly driving the wheels. Two (a redundant system) are involved in providing precise turning control and there is this 3rd one that gives you the "road feedback."
that's really good to know. are you one of Munro guy? :)
Speedr
Dual Motor Cybertruck
@Cybaba, it's probably just a wheel/tire balancing issue. Should be easy to fix. It's pretty common for 35 inch tires, even from the factory. Can't tell you how many Ford Broncos have a shimmy at various speeds due to balancing. It's actually amazing that Tesla does such a good job from the factory as yours is the first I've heard to have this issue!
BTW, mine's smooth well into the triple digits...on a closed course of course ;)
edc
C
Tesla Model X, Y, Cybertruck
Yes to all.
Mine occurs also at highway speeds due to the treads on the tires you get slightly more vibrations. NOthing crazy but you do feel it in the steering wheel slightly more.
2. make sure your outlets are off. huge cause of phantom drain. sentry mode also. If all those are off and you're still losing 3-4% check the energy tab under parking on the screen and see what it says.
YOu could also have a system fault causing it to wake up so you may need to do a hard reset, check the service menu for extra weird alerts, and put in a service request.
3. I wish rear view monitoring stayed on the screen while the side repeater lane change turned on as well..
lol I just did a video on all this my 1 month ct review. Should be out soon
Dazureus
US
'21 Model Y, '24 Cyberbeast
You're correct. The handwheel actuator (steering wheel motor) receives road wheel actuator(s) (steering rack power pack) sensors various data and translates that into handwheel torque for the drivers road feel feedback. Software *could* be in place to negate certain road or vehicle feels, like road wheel imbalance, road or wind pull drift compensation, soft end-stops for rack end of travel, etc. It all depends on how Tesla has programmed their SbW system. These can also be selected by choosing the various OEM installed calibrations.
I'm wondering if choosing a different steering feel will reduce the vibration; comfort, normal, sport, or whatever they are in the Cybertruck. It usually just changes how much steering assist the EPS provides, but with the SbW system, it might also change driver feel dynamics.
countryboy
East TN
M3P | CT FS AWD
Yes to all.
Tread is not the problem, size is. A perfectly balanced AT should have no vibration or feedback felt through the wheel. I have 33" mud tires on my Jeep that drive butter smooth at 90mph. But I've had countless big tires, and anything 35" or bigger is a pain to get perfectly balanced and almost always shake over 70-75mph. My last set of 35's (also Goodyear!) took 4 trips to the tire shop to get right, store manager had to do it himself. Guaranteed Tesla does not perfectly balance the tires that come out a little funky with imbalances from side to side (weights required closer to a specific edge). If I had this problem, I'd get them rebalanced until the vibrations go away. If that doesn't fix it, usually it's just 1 of the 4 that's being extra-difficult and a good tire tech should help you locate and replace the bad one if necessary.
Outdoors
Outdoors
North West Montana
S,CT,R2, Slate (order)
I don't know why you folks are messing with the tires. When my Tesla's start to shiver ?. I get a blanket.
Tesla Cybertruck My CT starts shivering around 76miles/hour. how is yours? Tesla-Uni-For-Bed-Baby-Blanket-Throw-Blanket-Sofa-Cover-Thin-Cotton-Bedspreads
Cybergirl
Illinois and Arizona
I feel a slight "shiver" in the squircle between 55 and 65 mph. Took it to Tesla Service. They said to drive my CT for a 1000 miles and see if it persists. I rotated tires front to back and still feel it.
agordon117
Ohio
cybertruck foundation awd
There's a lot of reports of this now. I wonder if it's wheel balancing (there IS feedback from the wheels to the steering wheel based on all of the information out there), or if it stems from the reported lack of a dead zone in the steering. If the control system hits just the wrong set of parameters, and there isn't any dead zone in the steering wheel, it's possible it could cause some back and forth movement like this.
Do I know any of this for sure? No, just thinking out loud. One of the issues requires a balance to be fixed. The other is a software update.
countryboy
East TN
M3P | CT FS AWD
The more knobbly the tire is, the more gaps in the tread, the more noise and vibration it imparts into the vehicle.
I have hundreds of thousands of miles on large offroad tires and fixing this problem, so I get that. The GY tires on CT are not very aggressive at all, and tread NVH is different than the topic of this thread, "shivering" or shimmying, or wobbling, or whatever you want to call it that is felt through the wheel in a cyclic pulling fashion, which is due to imbalance. Otherwise, we wouldn't have other people on the same exact tires going 100MPH without any issues. Inconsistencies inherent to manufacturing tires make it impossible to get it perfect, hence every tire needs weight to make it balanced. The bigger the tire is, the more potential for encountering a difficult or impossible to balance situation. I have seen this with Goodyear, BFG, Toyo, Interco, Nitto, and other tires, although some brands have better QC than others. Most brands don't usually have issues under 33" but have had this occasionally with car tires as well.
Kuiper__Belt
Madison, MS
Cybertruck - Cyberbeast
Telehealth Solutions Architect
No you will not feel wheel alignment/balance from low speed. The way you describe it, it is the most likely cause of the vibration.
Yup I had deep dish wheels on a 5 series that would cause my passenger seat to shake at interstate speeds. I learned quick that deep dish wheels + Mississippi pot holes don't mix... Never again lol
