New Cybertruck battery on the 2026 builds (4680 batteries)
kcroyaljosh
JC
KC
gov
I’m trying to figure out whether any recent Cybertruck deliveries are showing signs of the newer 4680 battery chemistry / dry-electrode pack that has been discussed over the last year.
Tesla has talked about producing 4680 cells in Austin with dry-electrode manufacturing for both the anode and cathode, and there have been reports that Cybertruck would eventually get the updated dry-cathode / newer 4680 cells. What I’m trying to determine is whether owners are actually seeing evidence of that in delivered trucks yet.
For anyone who recently took delivery, would you mind sharing:
  1. Delivery month/year
  2. Build month/year, if known
  3. Trim: AWD, Cyberbeast, or Long Range
  4. Approximate VIN range or last few digits only — please do not post your full VIN
  5. EPA/rated range shown at 100% after the truck has had time to balance
  6. Any battery pack part number, service screen info, or paperwork that appears to show a newer pack/cell revision
  7. Any noticeable charging curve, range, or efficiency difference compared with earlier Cybertrucks
  8. Whether Tesla service has told you anything about the pack version
I’m not trying to start a rumor thread. I’m just trying to collect owner-reported data to see if there is a pattern by build date or VIN range.
Poll question:
Do you believe your Cybertruck has the newer dry-electrode / updated 4680 battery pack?
  • Yes — I have documentation or service info showing it
  • Maybe — build date/VIN/range suggests it, but not confirmed
  • No — appears to be the earlier pack
  • Not sure — I’d like to know how to check
  • Following because I’m waiting to order/take delivery
Reactions: REM
Remus1961
Mike
Louisiana
1959 MGA, 1959 Triumph TR3A, 2026 Cyberbeast
1. June 11, 2026.
2. 05/2026.
3. Cyberbeast.
4. x988.
5. Will charge to 100% in a couple of days and then report back.
6. None that I can see.
7. No comparisons as this is my first Cybertruck.
8. I have an appointment with Tesla Service on June 25th and will ask them then.
Hope this helps.
Mike
ChiTownCT
OG Rivet Crew
Chicago
CYBERTRUCK
Probably not, I'm sure if a new battery was installed it would of made headlines as a new selling point..
Griswold
Chicago
Family Truckster
2027s will probably be the first noticeable upgrade over 24-26s.
Reactions: REM
speedstuff
El Dorado Hills
26 CT Beast, 24 FS CT Beast, 25 MSP, 23 C8 Z06, 22 GMC 2500HD
ecom
kpanda17
Grok:
In deliveries
“A June 10, 2026 delivery falls in the early-to-mid phase of the broader ramp. Some late-spring/early-summer builds may incorporate full-dry cells (especially if production lines were reallocated or yields improved), but widespread/standard use in Cybertrucks appears more likely in the second half of 2026 or later.”
Benefits to truck performance
“Comparable or Better Durability: Testing shows ~90% capacity retention after 2,000 cycles (roughly 600,000 miles equivalent in an EV), with no compromise in quality despite the cost savings.
No Major Immediate Range/Energy Density Boost: The dry process itself doesn’t automatically increase energy density or range (your truck’s cells are already at ~272 Wh/kg thanks to prior chemistry tweaks like higher-nickel cathodes and thinner housings). However, it enables thicker electrodes in the future, which could support higher density (long-term potential toward 300+ Wh/kg). Early full-dry packs focus more on cost than performance jumps. “
next big jump in overall performance will be in the 2027 4680 NC 30 version:
Gemini:
“By replacing the current baseline cell with the NC30, Tesla is directly addressing the two biggest real-world criticisms of the truck: towing range and cold-weather charging drop-offs.
The introduction of the NC30 brings several concrete benefits to the Cybertruck compared to the current NC20:
1. More Range Without More Weight (The Silicon Factor)
The NC20 cells powering today's Cybertruck use a traditional, pure graphite anode, which physically caps cell energy density at roughly 240–244 Wh/kg.
The NC30 Benefit: The NC30 mixes silicon-carbon into the anode. Because silicon can absorb drastically more lithium ions than graphite, the energy density jumps by double-digits.
Real-World Impact: Tesla can pack significantly more kilowatt-hours (kWh) into the exact same physical structural pack. This allows the truck's native range to push past its current limits and approach the mid-400-mile mark without making the truck heavier or sacrificing cabin space.
2. Faster Charging and Better Cold-Weather Performance
One of the hidden vulnerabilities of pure graphite anodes in large-format cells like the 4680 is that they struggle to move electrons quickly when it gets cold, which leads to slow charging curves.
The NC30 Benefit: Silicon-carbon allows lithium ions to move in and out of the anode matrix much faster.
Real-World Impact: The NC30 will improve the Cybertruck’s fast-charging speeds. More importantly, it helps mitigate the severe "charging slowdown" Cybertruck owners experience at chargers during winter weather.
3. Massively Improved Towing Capability
When a Cybertruck pulls a heavy load, it extracts continuous, high-amperage power from the battery pack, generating massive internal heat. Under the NC20, this rapid energy drain limits the truck's continuous power output capability.
The NC30 Benefit: The advanced chemistry of the NC30 handles high-power sustained discharge much more efficiently.
Real-World Impact: The truck will be much better equipped to handle heavy towing or sustained high-speed driving without the battery management system needing to throttle the vehicle's power to control internal temperatures.
4. Drastically Lower Production Costs (Pass-Through Savings)
The current NC20 was a stepping stone—it was a hybrid cell where Tesla dry-coated the anode but still relied on older, more expensive wet-slurry methods for the cathode.
The NC30 Benefit: The NC30 is built entirely on Tesla’s newly perfected 100% Fully Dry Electrode manufacturing line (both anode and cathode).
Real-World Impact: By eliminating massive, energy-expensive drying ovens and toxic solvents from the factory floor, Tesla projects a manufacturing cost reduction of over 30%. For the consumer, this lower cost per kWh gives Tesla the financial cushion to either drop the price of the truck or offer the higher-range battery upgrade at a much more reasonable price point.”
Cybertruck with 4680 NC 30 430-460 miles of range, could be within 12 months, 2027 or 2028 model year
will be amazing
Trbizwiz
Tom
Bradenton FL
Model X Plaid, Model Y Performance, Model 3 RWD, Dodge Challenger
Logistics
Maybe this will further differentiate premium from SAWD. Maybe SAWD can return to full time $59,990, and get the gen 1 dry cell, and Premium will remain at the current price point but get the gen 2 NC30 cell, with more power and range.
  • Love
Reactions: REM
Planet Earth
$59k CT delivered 6/26/26
That’s exactly the way I see it unfolding in future variants of the CT.
Premium trims and CB will enjoy the NC30 battery cells. Peasant trims will continue to receive the current NC20 battery cells.
AlDente
Roberto
Retired (of a fashion)
This has already been asked and answered. Yes the Cybertruck already has these new 4680 batteries.
https://www.cybertruckownersclub.co...4680-dry-cathode-process.53830/#post-30751156
Not really ... best guess is only mid to late 2026 Cybertruck will have the dry anode/cathode chem. Don't forget the primary benefit is cost reduction although some charging advantages may occur as the process evolves. My Feb 2026 build is getting the full EPA range of 320 miles at 100% SOC.
I'm only 3K miles in but I have been very pleased with range and charge speed thus far. It seems a bit better than my 2025 Model Y in achieving the full EPA range with vault closed, standard rims and tires. Speaking of tires, I picked up a large screw in the middle of the left front tire. Luckily and on a whim, I had elected to get the tire rim protection offered by Tesla a month ago so the tire replacement (happening today) is N/C. I chose the policy as I am planning some road trips this summer and wanted to be covered.
Jedi2155
Southern California
2024 Model Y AWD | FS Cybertruck AWD + FUSC
Dry Cathode was necessary cost reduction for Tesla to offer the $59k Cybertruck, so I suspect all the standard AWD models have dry cathode, and I suspect the entire line of CT's is now using the new cells. As been mentioned I don't think there is any real performance difference between the Cybercell V2 which is actually around 268 Wh/kg, not the 240 mentioned above by AI.
If there are performance differences between the cell types, Tesla could potentially be hiding it to avoid people getting upset over model differences at this point due to potential OSBORNE or FOMO. We won't know until we know, and right now there is no concrete information on when they'll release new battery technology.
kpanda17
We have no proof full dry cells are in Cybertruck current deliveries
Full Dry Cell Advantage vs Current Hybrid:
Grok states single improvement toward the customer beyond lower manufacturing cost is cycle life:
“The full dry-cathode 4680 cells (now entering production) are reported to achieve ~90% capacity retention after 2,000 full charge-discharge cycles.
This figure comes from Tesla’s patent-linked testing data and performance validation for the scaled dry-electrode process (both anode and cathode). For context in a Cybertruck (~300+ mile range), this equates to roughly 600,000 miles of equivalent driving before reaching 90% of original capacity — exceptional longevity for a high-nickel cell in a high-performance application. “
imagine, 600K miles
Trbizwiz
Tom
Bradenton FL
Logistics
imagine, 600K miles
What this really means is that after the Cybertruck body is completely worn out, as road transportation, the battery can still serve high quality second life as backup power. These will be parked next to every off grid home, and barn, and possibly some businesses with uninterruptible power supply needs.
kpanda17
interesting, the real use target is the Semi
We are enjoying adjacency benefits on our Cybertrucks to the Semi
Rippin1Gear
MJ
Seattle, WA
Foundation Cybertruck
plumber
You have to wonder what new cells the new Roadster will have to get that huge range they are estimated to get for such a small battery pack.
