(PCS) Failure
Maddmax
LA California
AWD
Truck wouldn't charge beyond 24A, after a few days got a 2 active alerts. Took it in for service today and they said it's a known issue happening to a lot of trucks, so much so they have put out a bulletin.
Tesla Cybertruck (PCS) Failure IMG_1888
dalton108
Dalton
Lawyer
Put out a bulletin to whom? Where?
EWELON
Rori
Wynnewood,PA
this is one of the most active topics in the forum right now. find one of the bigger threads and post your info there for people to see. your VIN would be the most useful along with your charging habits.
seussiii
FL
I feel like at this point we need a "my OG PCS survived" sticker.
Planet Earth
The big question: Have Tesla engineers discovered the root cause of failure and updated this $1700 part?
Eka
Ekaterine
The land between two rivers.
Model Y, Cybertruck
disabled
I think it is a soldering issue. The power FETs are pick-n-placed and soldered on the bottom of the PCB first, then the top side parts are pick-n-placed and soldered. During that top side soldering, the bottom side FETs' solder melts and they no longer sit flat. The FET's documents even said they needed to be soldered last.
Or the "top" went through first with the large parts glued down and the FET side was done last.
Tesla Cybertruck (PCS) Failure AISelect_20260424_074133_Firefox(2)
Tesla Cybertruck (PCS) Failure AISelect_20260424_074133_Firefox(3)
Seems like if they did ignore TN1378, there would be more obvious effects than just a little vertical sag/ misalignment.
Eka
Ekaterine
Model Y, Cybertruck
disabled
The remelting of the solder and hanging there suspended by the solder helps improve centering of the part.
I'd need to see a current board to know what they are now doing. The board Monro had definitely had FETs that were not parallel with the PCB. The impressions they made in the heat transfer goop looked like the FETs were off angle like the bottom side FETs for a board I designed. When we moved all the FETs to one side and soldered it last, it fixed the thermal problem. Thin supports during soldering can also be used to keep the parts level.
wb9vxy
Los Osos CA
2022 Y, 2024 X, 2024 CT
wb9vxy
Los Osos CA
I just went down to 24A charging on my CT.
I have a couple of road trips coming up.
Does the AC failure portend 48V converter failures and a bricked truck or or folks
seeing that the 48V portion of the PCS2 continues to home along?
Tnx
T3
Tnx
T3
Charging (DCAC) failures seem to be independent from 48V (DCDC) failures.
What looks like height variation may have been where the pink detached from the insulator rather than the fets. Per a contact, it takes some effort to de-pink the PCB after separation.
