Powershare is Activated / Enabled
schmo
Doug
Tesla Model S, Cybertruck AWD
Sorry for the multiple posts. My app is only letting me post one picture per message. The screen shots above were from a tutorial that appeared in my Tesla app along with the notice for the 2024.14.5 update.
Here is a screen shot of my truck’s “Controls” tab where I enabled PowerShare for my home:
Tesla Cybertruck Powershare is Activated / Enabled IMG_8896
schmo
Doug
Cool. I'm on with Tesla support right now and trying to work through why my Wall Connector is showing offline when it really doesn't seem to be.
My Wall Connector shows as "Offline" quite often in the app, but it is still connected to my Wifi and I can connect to it directly with an iOS app called "Wall Monitor."
akenis
Andrew
FL, USA
23 MYLR and (Apr-Jun CT AWD)
Pilot
jefflawless
Jeff
Fontana, CA
S, 3, 3, X
Just got an email from Tesla starting Powershare has been enabled. I've not had a chance to test yet.
Congrats. I just checked and everything is set except my gateway. Hopefully that will get a software push soon and I will be able to use PowerShare.
CybertruckRN1127
Palos Verdes Estates
Model S, Model 3, Model X
Does anyone have a support number to powershare? I have solar and powerwall, but have a partial home backup so my charger is not part of it and the panel said do not add new loads. Installers will not touch it. This means I can't use powershare.
CybertruckRN1127
Something seems wrong to me, but when I reached out to Tesla about it yesterday they told me the software wasn't coming until June. I'm not sure if they're misinformed or if what I'm seeing is expected at this time. :/
How did you reach out? I need to speak to them about powershare.
bwilliam79
Brandon
Prosper, TX
https://www.tesla.com/contactus?issue=energyProductSupport
Just know they seem to be a little lost as well. I still don't have an answer to the issue I'm seeing where my UWC is showing online in one view but offline in the view where I configure a limit to how much battery Powershare can consume. My gut tells me it's an issue where my gateway still needs an update, but supposedly they're looking into it.
Zaimor
Chris
Van Alstyne, TX
24CT, 20MY, 14MS
AWS Security Specialist
I had the same issue with the wall connector at first. It reported having WiFi issues though it was connected to WiFi. I had to open a ticket to get that sorted.
I was told this is a firmware issue the team is working on. Have the same issue with mine.
CybertruckRN1127
Thanks, but they are no help. They transferred me around and told me to go to the delivery center which the DC just told me to connect the Powerwall and Wall charger team. I've been stuck in this loop for a month.
SumitNarayan
Sumit
Tennessee
Tesla Cybertruck Powershare is Activated / Enabled IMG_0238
I was able to test the PowerShare and it works greate. After the email my Gateway went offline so i just did a restart of the Gateway by powering off the wallcharger and once it was on again everything showed as online and then I simulated the power outage by switching off the main breaker and the power was switched to Cybertruck.
bwilliam79
Brandon
Prosper, TX
Well, look at that. Despite the Tesla app making it look like things aren't quite working yet, it absolutely does if you kill your main service. Thanks for the tip!
Tesla Cybertruck Powershare is Activated / Enabled 1715443092011-z7
