So it’s been a while. How are things with the experiment?
Thought of this while browsing today because I ran into this:
https://a.co/d/eFFRKrV
any of you use something like this?
Tesla Cybertruck Preparing trailer range test with and without a wind deflector.... IMG_7770
BornToFly
BornToFly
Richard
Utah
S, X, 3, Y and CT
I don't have access to another trailer right now. In the spring, I think I will rent an Airstream 25ft. I want to see how much I can extend the sides without hitting the trailer in a max turn. I also will add vortex generators, and then take an actual trip. I will definitely post my results.
I think the deflector you posted is too small and would be way too far back from the trailer. The goal is to have as little gap as possible, and probably the vortex generators to help reduce drag from the gap.
Bridgeboy69
Trying to Survive
Something like this is what I want simply to deflect air over the top of the RTT on my roof rack which is just a flat vertical surface 45" wide by 10" tall. I italicized something like this because this one doesn't appear to be a good one based on reviews...particularly this one which seems to basically prove it:
Tesla Cybertruck Preparing trailer range test with and without a wind deflector.... 1765381043251-et
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
Ivessm
Stew
PA, USA
Is this pic on long island NY?
Nope, Assateague Island, MD, just south of Ocean City MD. Best camping beach camp sites in the USA. Wild ponies and deer included.
I spent an entire day building this. Attached to the truck using the 8 crossbar mounting points. I can remove the eight screws and remove the entire structure with my wife on the other side. Or I can remove 4 more screws and remove the front section separately from the rear section. Will start covering it with corrugated plastic sheets tonight.
Hopefully can get a range test with an Airstream Basecamp or Bambi later in the week if I can find a rental in SLC. Will test the same out and back with and without the wind deflector. I don't know if the drag behind the deflector will be worse than the drag from just the trailer. We will see....
How did you attach to the Cybertruck mounting studs?
BornToFly
BornToFly
Richard
Utah
S, X, 3, Y and CT
Yes. I originally cut some hardwood and screwed blocks to 90 degree metal brackets. But I'm worried about the strength. So I ordered 1/8inch thick 3 inch aluminum angle metal and cut them to be 3 inches wide, and cut one side to be 7/8 wide to bolt to the truck. 4 on each side. (I haven't drilled the holes yet that will go through the actual wind deflector yet since it's winter).
https://www.amazon.com/dp/B0FT2K7X93?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
Tesla Cybertruck Preparing trailer range test with and without a wind deflector.... Imag
Awesome, thank you!
Hadn't thought of using Amazon for a metals source.
BornToFly
BornToFly
Richard
Utah
S, X, 3, Y and CT
If I end up buying an airstream trailer of my own, and range is acceptable with a 27ft Airstream, I may rebuild the wind deflector for real world use using 1 inch square aluminum tubing instead of the cheap wood I got at Home Depot. Can get 21ft lengths pretty cheap.
Tesla Cybertruck Preparing trailer range test with and without a wind deflector.... Image 1
Speedr
Dual Motor Cybertruck
What's the range with the 27ft Airstream?
BornToFly
BornToFly
Richard
Utah
S, X, 3, Y and CT
I don't know yet. I plan on renting one in the spring and doing a several hundred mile trip with my wind deflector. I will report the data.
'23 MYLR, FS Cyberbeast 280xx
21' pieces will be tough to manage. I'd consider building a forward and aft piece that connect in the middle.
Gaximus
Mead, CO
Software Developer
You should also taper the rear of the trailer, from a quick search, a tapered rear end, is more importable and has a bigger affect than tampering the front of an object due to the low pressure wake behind the vehicle that pulls the truck back.
Yeah, but my trailer doesn't have much in the way of mounting points...
2" receiver though...
Starting pulling measurements for a ten foot high (from ground) deflector
Also researching low rolling resistance tires
