- Ace
- Jan 22, 2025
- Arizona
- 2024 foundation AWD, 2024 model x
- Occupation
- Trauma Surgeon
Facts always win. At least, that used to be the case.It's not a runaway process as long as the frunk can lose heat to the environment faster than heat enters the cooled compartment.
The frunk lid is around ten square feet of single layer stainless steel.
Stainless steel has a thermal conductivity of ~14W/mK. At a thickness of 1.8mm (0.0018m), that's an R value of .000125. Mixing units for simplicity: 1/R*10 = 80,000 for thermal transfer
A 24x14x14 cooler is 12 ftΒ² of area. With R-3 insulation, that's 1/3*12 = 4 units of thermal transfer.
The frunk sheds heat 20,000 times better than the cooler gains it. If the cooler wants to be 34 degrees and the world is 90, the air in the frunk needs to be barely over 90 for the cooler to work. As long as it can handle a 56 degree differential (which it should) things will work fine.
