boley
Boley
Gulf Coast
Cybertruck AWD 2024
Consultant, CEO
Where did you source the T slot rails? I may try to do this, but shorter as to not use the top rack slot which I'm using for a lightbar.
If I need it quickly I buy T-slot here: McMaster-Carr
They probably have a warehouse nearby that can deliver to overnight by ground at reasonable prices.
If I have time to wait I buy it here cut to my exact length: Tnutz
habendanio
Henry
Northern California
Cybertruck Dual motor
Electronics/Electrician
I’ve done similar with 2040 extrusions and a custom bracket to interface with the stock mounts under the plastic doors. Then used 2040 extrusions to connect side to side. Have L-tracks mounted at bed. Solar panels above glass roof, starlink mini mount at top of bed. 50’ light bar mounted at forward just above the windshield. Plus 3d printed parts to clean up the look.
ThatGuyBo
Maryland
For anyone reading this, do NOT use PLA. It will deform and fall apart in moderate summer heat.
Yah i dont know if thats true, I have some PLA rifles ive printed, 22lr of course and they have sit in the sun with no issues. Great job creating the design tho, I would love to have more time to design and print things out of my own ideas also for the CT
PLA (Polylactic Acid) degrades with UV exposure, thermal fluctuations, and humidity.
https://pubs.acs.org/doi/10.1021/acsmaterialsau.3c00065
https://link.springer.com/article/10.1023/A:1021808317416
5280cyber
Jeff
Denver
I love this design. I’ve been looking for risers like this to attach fly rod holders made by Trxstle directly to the riser. If I don’t have a 3D printer, how best to find a producer to make these for me? What material is best to survive the high UV environment of Colorado?
MrMoparMan
MrMoparMan
Tesla Swapped 72 Plymouth Satellite, 2004.5 Ram 2500 Cummins, 2015 Ecoboost Ford Transit 250, 2012 Chevy Caprice, 2007 Dodge Charger SRT Superbee, 1969 Turbocharged Dodge Dart 340
Pilot
I can probably help you print a set, where are you in Colorado? I am in the Denver area.
I have been using the rack a lot at my house project. I have had good luck with TPU, I like how tough it is and how provides some flex. Nothing will last forever in the intense Colorado UV, but it should last a long time. I can get them made in billet aluminum for $$$, but I think I still prefer the TPU.
Tesla Cybertruck T-Slot 8020 Roof Rack DIY - 3D Print Your Own 1752517392377-6d
5280cyber
Jeff
Denver
Also in Denver. Best way to go off forum?
boley
Boley
Gulf Coast
Cybertruck AWD 2024
Consultant, CEO
My two online sources for T-slot is Grainger (fast) Tnutz (cheap).
boley
Boley
Gulf Coast
Cybertruck AWD 2024
Consultant, CEO
Very Nicely Done!
MrMoparMan
MrMoparMan
Pilot
New Risers for 1.5"x3" T-slot cross bars. Easy to install, just two fasteners per side.
Tesla Cybertruck T-Slot 8020 Roof Rack DIY - 3D Print Your Own 1755043467519-n4
Tesla Cybertruck T-Slot 8020 Roof Rack DIY - 3D Print Your Own 1755043573174-74
Tesla Cybertruck T-Slot 8020 Roof Rack DIY - 3D Print Your Own 1755043613717-mh
J.Graham
BC
FS AWD & Model Y LR & 993
Thanks for sharing the files. Just had a friend print the mounting points for a similar rack I’m working on (the original set in the first post).
What hardware did you use to secure the mounting points to the truck?
Cheers
Kryptek
Alaska
Are the files updated to most recent version? got some PACF12
