TESLA Wall charger SECURITY
Status
Not open for further replies.
sirfartsalot
Baldar
North America
Subaru Outback, Honda Pilot, Toyota MR2 Spyder
Retired Engineer
For what it's worth, that erudite advice recommending a NEMA 14-50 outlet and adapter for the mobile charger in lieu of the Tesla wall charger?
Requires a pricey dual pole 240v. GFCI breaker for that NEMA 14-50 receptacle AND a pricey NEMA 14-50 adapter for the mobile charger.
Tesla wall charger incorporates GFCI and is plug and play. However, it is vulnerable to theft.
I agree, good option to put the Tesla wall unit in a lockable cabinet large enough to include the cable and if you have alarm system at the house put a alarm sensor/contact on the cabinet door.
Just one example there are others
$240 Charging Station for Tesla Model 3 Y Charging Cable Organizer Box Accessories Third-Generation Charging Pile Wall Mounting Connector Metal Home Charger Box for Model X S Indoor Outdoor
https://www.amazon.com/YONZEE-Organizer-Accessories-Third-Generation-Connector/dp/B09PD9N6KR
$75 Tesla charging pile charging
https://www.ibzstore.com/?product_id=273527861_75
If your county/city has electrical code standards it will probably be illegal to make Tesla wall unit removable (has to be hardwired).
The second link is broken.
firsttruck
mx
Tesla Cybertruck TESLA Wall charger SECURITY 550-105
$70 Steren FastHome Surface Mount Network Enclosure, 19
Model: 550-105
https://www.cablingplus.com/products/steren-550-105-19-inch-surface-mount-network-enclosure
The Steren 550-105 19ā€ FastHome Surface Mount Network Enclosure is designed to house commercial and residential electronic components. It is ideal for security and networking applications. The 550-105 is a surface mount box that includes locking hardware, hinged cover, multiple knockouts and pre-punched holes, and raised mounting rails that create a clean wiring channel behind mounted modules. The Steren 550-105 19ā€ FastHome Surface Mount Network Enclosure features a white textured powder-coated corrosion-resistant finish, and offers standard hole spacing which allows flexibility for mounting modules. The Steren 550-105 dimensions are 14 9/16"(W) x 19"(H) x 4 5/16"(D).
Specifications:
Includes: (1) 550-105 11ā€ FastHome Surface Mount Network Enclosure
14 9/16?(W) x 19?(H) x 4 5/16?(D)
Standard hole spacing allows flexibility for mounting modules
White textured powder-coated corrosion-resistant finish
Mounts on surface of a wall Multiple knockouts and pre-punched holes
Raised mounting rails create a clean wiring channel behind mounted module
Captured hinge cover design for easy access
Keyed latch for positive closure and security
The UMC is $200. Adaptor is $45. A GFCI receptacle is $120. Total is less than the cost of the Wall Connector. You wanted theft proof. There you go.
Professional installation of any of these solutions is going to be several times that amount but otherwise that is by far the most affordable and secure way to ensure your charger doesn’t get stolen.
A long time ago someone told me it’s easier to attract bees with honey than vinegar.
sirfartsalot
Baldar
North America
Retired Engineer
Model: 550-105
Specifications:
GnarlyDudeLive
Darin
Chicago
Model Y Dual and Cyberbeast
Honestly you are all trying to figure out how to prevent it from being stolen by reading into it way more than was asked. This is NOT what the OP asked. They asked can it be removed easily? I can read enough into it that they want to remove it when they are not on premise. Maybe a reword of the question is can the OP easily remove it themselves in a fashion that they can then store it elsewhere or take with them?
I can understand the OP's frustration here. LOL
Gave an option for that too and still got whining.
Some people can’t be pleased.
Newton
Newton
East Bay Area, CA
p̶r̶i̶u̶s̶ c̶,̶ y̶o̶t̶a̶ p̶i̶c̶k̶u̶p, ā¼•äø«ā»?尺セ尺ㄩ⼕长
i dont have and havnt seen a tesla wall charger
but based on the replies, it seems to be bolted to the wall, thus not easily removable. im sure you (the owner and your electrician) could simply make it removable when you install it.
Dont get a Tesla, or any, wall connector if you want this kind of security. Run conduit to your charging location and install a 220v receptacle in a waterproof enclosure. Then just unplug the cable when not around.
The Wallbox has a QR code inside it that refers to its serial number and passcode.
Change that, and it cannot be used by others.
Thieves intent upon scrapping your stuff will scrap your stuff. There's no way around that.
PS, you hear about J1772 chargers being stolen because they don't lock to the car and they don't have Sentry Mode and many are just third party pieces of crap that don't even have a solid cover.
Bill906
Wisconsin
Jeep
Oh… Now I get it, The guy on First base is NAMED Who.
The wall charger is designed to be hard wired. Removing it and leaving a hole with wires hanging out of it is probably against code. A much more elegant solution that won’t be against code is to install a NEMA 14-50 Outlet.
I’m confused what you mean by the wall charger is plug and play. A NEMA 14-50 outlet and the mobile charger is literally the ā€œplugā€ part of plug and play. But I’m also confused about Whatā€˜s on second. So I’m just going to hang out with the shortstop, I don’t give a damn.
OneLapper
NE Conn
BMW 328d Sportswagon
So you drive a Prius, huh? I have never seen a Prius driver with a smile on his face.
I bet you're not a happy Prius driver, and you feel like spreading your unhappiness among us generally happy, albeit sometimes impatient, CT (that's short for Cybertruck) reservation holders and CT/Tesla fans.
Post up for people to take you seriously.
I can't count the number posters with single digit posts that jump on here and stir up trouble.
You may be new here, but you're type is old and tiresome.
Hey. Did you happen to post on the Supra forum and tell everyone it's actually a BMW? That didn't make you popular over there either, huh? Maybe someone else is using your handle.
PS, for any sort of cabin or outside use I would suggest to have a cabinet for the cable anyhow. Keeping it out of UV and hot/wet will reduce the amount of aging the insulation takes, and keep it working longer.
PPS, someone who'd steal a wall charger isn't going to bat an eye stealing a wall outlet, either.
Status
