SeasonedTech
Wilmer
Bay Area
3,Y,CT VIN-12XX
Ever looked at an accessory and thought, 'How do I install this?' Me too! But I figured it out! Check out my short 30 second video to see how it's done. Enjoy, Cybertruck owners!
wh1t3rbb1t
Cybertruck Founders Edition
Cybersecurity
That was helpful. Thanks! That’s probably why mine isn’t locking very well due to me not aligning to the holes properly.
NormalSpeed
I have a Vault bed liner. I assume there will be no way in hell the Vault Divider will go into place with that liner in there. It is 3/16” thick.
SeasonedTech
SeasonedTech
Wilmer
Bay Area
3,Y,CT VIN-12XX
Interesting. I’ve installed it over that area in more than one position with no issues.
someccie
Maryland
Cybertruck Beast
Network Dude
There is a known issue where some Cybertrucks have a bowed upward bed liner and therefore the Vault divider does not lock into the L-Track when used over that portion. If you have this issue, when you place the vault divider over the liner, the sides will stick up too high and will not fasten into the L-track. You do not need much force to lock the divider into the L-Track and should certainly not force it to lock into place.
Recommend putting in a service request if you are running into the issue. Tesla knows there is a problem and will replace your liner under warranty.
I have a request open for mine and will have it replaced next week (after a long wait due to personal and work travel).
TickTock
Phoenix, AZ
Electrical Engineer
Mine isn't bowed up but the bed (front and rear) is about 5mm too high for the divider to work as-is. Had to remove both feet and do Mark Z's modification to get it to fit. Even then it takes some effort. The divider now rests firmly across the tops of all the ribs when I manage to get it in place. So before cutting your bedliner make sure the tops of the ribs aren't the limiting dimension.
gadgetmerc
MN
XP CB
I didn't realize there were bed liners available. Kind of torn if I want one.
I have the vault divider which I like to use. Makes it super easy to stop things from moving around. I throw a clamp on it to stop things from moving laterally or even a strap.
