Tonneau cover leaks
I had the extra slat installed. Did not help the water leak one bit. As stated above, all the water comes in between the roof glass and the appliqué.
Comes in in buckets, can't put anything rain vulnerable in the back
Can the tonneau cover be made waterproof? is the question I pose.
we just went through a rainstorm that was a few days long here in Los Angeles with reports of flooding in some parts
it even dropped a little hail and at some point, my backyard was under 2" of water
A lot of water came down so yesterday I'm doing some clean up.
open up my truck bed with my tools inside. and it's always fun to find your tools are under water and the toolbox is completely full of water. the moving blanket is also completely drenched. it was all dry when I put them in my truck under a cover.
I mean this kind of defeats the purpous right ?
is there a soulution?
Real solution to getting the vault dry.
1. A time machine to buy one of the trucks that was made with the extra slat and propper sealing, gets you 98% dry
2. Go to a service center 1-20x and hope to get the right person to do the fix.
3. Do what this guy I met at a supercharger did, and black silicone the whole thing, looked TERRIBLE but he said he used the truck for work and had some work tools destroyed by getting soaked. (he said it was OK that I took pictures and shared)
Full post with more pics here
https://www.cybertruckownersclub.com/forum/threads/100-waterproof-vault-using-black-silicone.46646/
Tesla Cybertruck Tonneau cover leaks 101142-f6ac4051b932e952c2fb8b2cc8d24d17
Tesla Cybertruck Tonneau cover leaks 101143-851037c405b31b81893adb825ead3c9
asl
The cover itself is quite resilient to water, as there is little to no penetration between the slats nor at the sides. There is a little intrusion at the tailgate seal, but the real culprit is the gap between the tonneau appliqué and the roof glass. When poorly sealed, you can gently pour a glass of water on the roof and watch most of it splash into the bed.
There are fixes that involve improving the seal on the appliqué, such as this one:
This worked for me.
I want to do this, but I was wondering if it’s possible that the rubber seal might trap water inside. And then if that water freezes it could break the roof glass?
kpanda17
Guys, we've heard from a new 2026 cybertruck owner, his does not leak.
They've solved it. Lets all have ours fixed at the local Tesla Service Center.
Report back as each is fixed.
EVnewbie
texas
F-150
What an embarrassment. It’s pretty sad that a lot of service centers, including mine, say that “it’s not supposed to be waterproof” and that the leaks are “in spec”. Bullshit. Sloppy ass assembly is what it is.
kpanda17
Tesla Cybertruck Tonneau cover leaks 1767154334802-j
EVnewbie
texas
F-150
That’s all well and good, I had an F-150 prior to this, and it wasn’t “waterproof” but it was nothing like my Cybertruck. I’m talking INCHES of rain leaking in this thing. I don’t mind dampness, or a few drops around the sides. It pours into the Cybertruck vault. Unacceptable.
kpanda17
let’s get them fixed by Tesla
I had my “fixed” once
Def improved but need to test with video
Need to wait for a warm day
eser50
Enrique
Oceanside, CA
'24 AWD CT, '18 Model S, '16 Mustang GT, '19 XC90
Tesla Cybertruck Tonneau cover leaks 1767156821960-bi
I added a small piece of weatherstripping and haven’t had any leaks since.
It’s not meant to be watertight, but this certainly helps!
Didn’t have a drop of water in the bed from the socal rains last week, but I have seen some water in there after some pressure washing.
T3s1a
Orlando, FL
Did the exact same thing with my truck and haven’t had any leaking since. Had the extra slat installed and it did nothing for leaking (still worthwhile because leaves/acorns/debris would fall into the channel and drop into where the cover retracts when operating). Once you take the appliqué off it’s easy to see where you should add a strip.
koolio
Greater Boston, MA
Are there any concerns these aftermarket fixes could void a warranty? If your tonneau gets stuck and you bring it in for servicing and you've put a bunch of aftermarket seals on the truck, is there a chance Tesla wouldn't cover tonneau fix?
This is why I don't want to modify the truck. If Tesla won't fix it, then I am stuck with a swimming pool.
No, it doesn’t void the warranty. It’s literally replacing the foam seal with one that actually seals between the appliqué and roof glass.
koolio
Greater Boston, MA
Will be interesting to see what change they made on the 2026s…
kpanda17
not complicated, better seal at the applique to glass edge
stronger seal at tailgate end
CyberTrk
Cyberspace
サイバートラック
Note like the sloppy job shown in the video,
using two disjoint pieces of rubber not sticking to the frame and dangling !!!
Tesla Cybertruck Tonneau cover leaks CT Roof leak e
Tesla Cybertruck Tonneau cover leaks CT Roof leak h
