Towing Camping Trailers
No-ICE
Ron
2002 Tundra
I see a huge opportunity for an auxiliary battery packs for EV trucks. Something to put in the bed of the truck when towing. It would be best if plugged in to an aux port while towing, thus available while towing. And recharged while the truck is being charged.
N.ICE
The CT advantage is the 4680 cell. While there are no available specs yet, it certainly seems like the form-factor, chemistry, and tablessness (untabishness? tabulatory?) features will enable much faster charging rates.
If an EV battery pack can be charged from 20% -> 80% in the same amount of time as a gas fillup, then "EV range" isn't even a discussion anymore. I doubt that's achievable with the current technology, but supercharging a CT should take minutes, not hours.
I suggest either of the following:
Tabuliscious.
Tabulous.
Range matters in regular cars and truck too. Its just that most cars and trucks have decent range. It’s the whole reason big trucks have 25+ gallon gas tanks instead of 15 gallon ones. You get 500 miles of range when you are empty and 300 miles of range when towing a load.
Firetruck41
Ben
SW Washington
Tabuliscious.
Tabulous.
My 1st world problems, now that gas is so expensive, the pump shuts down at $100 at Costco, which is before I can fill my 34 gallon tank, so I have to go through the payment process again to finish filling the last 2 or 3 gallons.?
I had to deal with that with our RV. We stopped driving it long distances because it cost about $0.50/ mile to get anywhere.
The Cybertruck pulling it’s full 14,000 pound load might only have a 150 mile range, but it’ll still only cost $0.10-0.15/ mile to drive. Also, regen braking will save you tons on brakes.
Just get used to not filling it up. Consider it practice for when you have an EV and that last 20% of battery takes twice as long to charge as the first 80%.
ldjessee
Lloyd
Indiana, USA
I am hoping that as more EV pickups come out that the need for aerodynamic trailers will become something owners seek out.
If one manufacturer makes one trailer that is really aerodynamic with one truck (because the 'shadow or wake of the truck will heavily influence the aerodynamics of the trailer, I think it will need to be designed for that truck) makes a big splash (be it movie, TV show, internet famous video) then it will push other manufacturers to compete.
Also, the software keeps getting cheaper (but some people will not validate or always understand what the software tells them) so hopefully more and more manufacturers will take advantage of that...
I am also hoping that with rare wheel steering will also help with some trailer towing issues.
I am sure some high end trailers will have regen braking and a battery pack to store that energy in... but not so sure about using them to move the trailer around... Then it would have to register as a vehicle, pass all the same safety standards and the price will really jump up.
I’m not sure it would be worth having that big of a cell if they couldn’t use it for drive wheels. The cell would fill up after the first big downhill then just be along for the ride for the rest of the trip. As someone else suggested, just get a lighter trailer and the 500 mile CT at that point.
ldjessee
Lloyd
Indiana, USA
There are trailers now with batteries as big as the one in my Leaf (I know, not that big) and they cannot do regenerative braking.
Brakes are throwing away energy, turning energy into heat and ground down brake pads and rotors... Why would not someone see the advantage of turning that into energy they can use to run their camper once they park it?
And never think of having the trailer be able to provide motive force to the trailer wheels.
I do think it would make sense to feed some or all of that power back into the Cybertruck... say at a pit-stop or such... Just not sure if Tesla will make it possible to charge the pack while in motion.
I hope Tesla adds that feature (charging while in motion), as then battery back in trailer, in the bed, or even a generator on a trailer hitch platform could really help some people in their situations... but most people will probably never need that feature, so I see it low down on the list.
I could see that being a feature of the Semi first... if the trailers there have batteries and you can avoid waiting to charge the Semi and just drop the trailer, pick up a new one (with full charged battery) and take off, pulling energy from the trailer to power and charge the Semi while underway.
For those partial loads or loads that do not weigh that much, seems like the smart thing to do.
Watching some videos of how long Semi drivers wait to even be able to back their trailer into a spot to get unloaded, probably not worth it... just make a couple of charging spots for trucks waiting to back into a dock and some charging spots at the dock...
If you aren’t using the energy while you are driving, regenerative braking will quickly fill up the battery then it’s worthless.
The whole reason regen braking is interesting in a vehicle is because you have a way to use that energy immediately and repeatedly. If it just fills up once then you have to drag it around worthless for the rest of your trip, it ceases to be interesting. Just plug in when you are home, then you don’t have to deal with a complex second braking system that is dead weight after the first few miles.
If there were some kind of vehicle to vehicle charging standard and you could charge while driving, then regen braking on the trailer would be awesome. I just don’t see it as being interesting unless it is actually doing work while the vehicle is in motion because all of that regenerative power is just lost.
ldjessee
Lloyd
Indiana, USA
RE: Regen battery filing up and being useless...
If it saves you from paying electricity at a camp ground, maybe not?
Also, not sure how much breaking would be done and thus not sure how fast that battery would fill out. If the trailer was going as far as my grandparents when when they moved their RV from one park to the next, it was 300 to 500 miles and only getting energy from braking... if it had a 50 to 100 kWh pack, how long would that take to fill, or even do the 20 to 80% charge? I do not know... but if it would not be filled up in a 300 mile trip, then it is probably not worth doing anyway.
RE: Battery worthless if not providing motive power (either directly or thru the Cybertruck)
I get why you would want that, but I also do not see a trailer being able to provide motive power without getting classified as a vehicle and requiring to meet certain safety or atleast some regulations that would increase the cost and weight of the vehicle.
And because you do not see its worth does not mean others do not see it as worth while.
A 20kWh battery costs what $2 to charge up at home? The electrons don’t weigh anything.
If you are just looking for “House” power, solar panels on the RV would be a better investment. Charge up at home for free, then get power when you are on site as well.
