Wind, Bearing, or Coolant Noise?
cyberowner79
James
Virginia
Cybertruck AWD 2024
The Tesla Service Center has been unable to figure out what is causing the noise in the attached video. You can hear it start at about 17 seconds in. They have replaced the windshield and adjusted the suspension but this has not fixed the issue. I saw another post on purging the coolant lines and did this in service mode without any success. I am curious if others have heard this noise and whether or not it is related to wind, bearings/motors, or the HVAC system.
Other interesting notes, the noise goes away around corners.
Video of Noise
trentsize
Trent
West Yellowstone, Montana
www.trentsizemore.com
Cybertruck AWD, Model 3 LR
Wildlife Photographer
The whistling sound? I believe I get the same thing. Some days it’s there, others it’s not. It seems tied to HVAC or the front motor area.
mcorf
Campbell,Ohio
2021 LRAWD Model Y. 2024 LRAWD Model 3. 2024 Foundation Series Cybertruck AWD.
I get that same noise at around 40 mph but only when it's cold outside, like 40F or below. This week it's been mid 50's and I don't hear it. SC told me they thought it was related to the heat pump.
cyberowner79
James
Virginia
Cybertruck AWD 2024
If it was related to the heat pump, I don't understand why it would only happen while it is cold outside. The coolant system does not use different items when in cooling versus heating, it's just a closed loop with a reversing valve. For mine, the sound does not fully disappear, I can still hear it in warmer temperatures but it is not as shrill, it seems more muted but still there.
Simicyber
Chris
Socal
Cybertruck AWD
What’s the vin range of you all having this issue? Mine is 47k. Seems to be ones built around October 24
There is no reversing valve.
The cabin has dual condensers (cabin heat) and an evaporator (cabin cooling).
The supermanifold has an evaporator and a condenser.
mcorf
Campbell,Ohio
My VIN is 24,600, built in August.
QuantumGlen
Glen
Los Alamos, NM
Model 3, Model Y
Scientist
I have the same noise issue. Also 40-60 most noticeable. And seemingly more when cold. Mine goes away on a gradual left curve. But is present on straight away or right hand curve. I call it a whistling or rustling noise. Definitely up front somewhere.
Sif
Sean
Virginia
2024 Cybertruck
I as well have this noise. I don't believe I had this noise when I first got the truck.
As mentioned above mine disappears when doing a left hand turn and it seems to be gone during the rain.
cyberowner79
James
Virginia
Cybertruck AWD 2024
My vehicle was delivered in November with a VIN of 48544.
cyberowner79
James
Virginia
Cybertruck AWD 2024
I hadn't noticed the rain difference, I will have to see if it is the same, I wonder why rain would make a difference.
BorisJGR
Boris
Cybertruck, Model X
Marketing
I have the same noise, 32,000 VIN
Mine completely goes away when you punch the throttle, while leads me to believe that it is not wind noise and has to be related to something with the motor. Or any least, with a rotating part of the front of the truck. If it was an ICE car I would think bearing or something rubbing a wheel or brake pad.
it’s very annoying and the service center says it’s normal.
Has anyone had any breakthroughs?
Simicyber
Chris
Socal
Cybertruck AWD
Mine is in service again and told within spec.
Flex3269
Tony
Model S
Entrepreneur
Mine has that sound too, it’s like someone turns on a valve to let water run. It seems to start when I reach 45-50mph and that’s just driving straight. My truck was made end of Jan 2025
