Windshield wiper/fluid not covering or cleaning evenly
cofree
colorado
tesla model 3 LR dual 2018
ok, good to see it wasn't my fault for using rainx. I'll probably switch to something else when I refill and keep the rainx for our other Teslas. Hopefully that will be about when Tesla will do a hardware fix.
NormalSpeed
Fun fact about RainX. If you get chips in the shield and want them corrected, that RainX makes it a royal PIA for the correction. It must be completely gone from the chip. I quit using it as in Colorado I am doing chip correction at least once a year. Not worth the trouble.
Philly Burbs
JIm
Philadelphia Suburbs
2024 Cybertruck ford f-150 Audi Q5 Porsche 911
Self Employed
I tried rainex , don't bother , the orafice holes at the end of the blade need to be larger or the timing of the spray needs to be inverted, spray on the down stroke and wipe on the upstroke. This will give the washer fluid time to spread out. Hopefully software update can fix it.
NormalSpeed
Agree. Tried to see if it is spraying on the down stroke and it isn’t. That may be a game changer.
The problem with spaying on the downstroke is that it's behind the direction of travel, so the windshield will be momentarily obscured. However, they could start the spray a little early, say on the last 2-3 inches of travel, so that the blade is "primed" with extra fluid ?‍♂
Sleipnir 1
Hal
Roseland, VA
Cybertruck Foundation Series
materials scientist
I also had streaking problems with RainX. The cheap blue methanol solution works fine!
We have this issue too.
I have seen suggestions that this issue is common with people using RainX washer fluid.
What washer fluid is everyone using and how does this correlate to the issue?
I filled with RainX a couple of weeks ago, but in Colorado snow I will probably need to fill again within a month.
Thunderstrike44
Brian
North Liberty, IN
2024 CyberTruck Dual Mtr., 2007 Jeep Rubicon, Ram 1500 Diesel
Control Engineering Programming Manager
Me Too, same issue for me here in the salt belt. Maybe that's also why I turn OFF the wiper and it keeps turning itself back on and dry wiping the windshield, very annoying.
Philly Burbs
JIm
Self Employed
Wiper ghost in my truck too , leaves the wiper down at the bottom just to annoy me also.
Bhcyber
Ben
East Coast
Cybertruck and other tesla
Less than ideal application of fluid and squeegee. On the drivers side it’s adequate. On the passenger side however, the tension to the glass is lacking. Also the amount of fluid applied isn’t enough to fully clean the window. Maybe 1/2 which is needed.
Here’s a pic. 100 miles today in snow and road muck highway conditions.
Same here. I had to stop by a gas station and use their windshield clean bucket by the pump to clean the windshield.
NormalSpeed
Completely unacceptable and unsafe. This must be corrected. For a vehicle of this price point they have to do better. Full stop
Bhcyber
Ben
East Coast
buthe boss is now busy running the country
Totally unacceptable. Fix it.
for most of us, this is the first winter for our CT, but how can their winter test team dont know about this
bentoncalder
Benton
Vancouver BC
Cyberbeast, Model Y
After delivery had the same issue. When service the tech needed to tighten the bolt on the wiper arm and make an adjustment so the pressure was equally on the passenger side. You may need service.
Please tell us! This needs to be told to every service centre…
