- May 27, 2024
- SE Michigan
- Cyberbeast
There is no issue using properly sized and terminated aluminum wire in an EVSE branch circuit.note: that looks like aluminum wire to me. Not sure why tf anyone in their right mind would would be using that for an EV charger. Prone to disasters just like this.
Meters are fed with Al, main panels are fed with Al, subpanels are fed with Al, other high current loads are fed with Al. As long as they didn't make the error of landing the conductors in the Wall Connector, it's a lower cost option for long runs.
It increases the total heat output from the wire in the box, but it reduces the transfer of heat generated by the connection. For a short run, it might reduce peak temperature, doubtful it is needed though.Doing it wrong 100 times then. Unless someone can correct me, I can't find a single engineering reason to do this. Coiling wire INCREASES the thermal mass load; not the other way around.
