Cirrus SR22
- Dec 10, 2023
- California
- Cybertruck
- #1
After getting the CT on Wednesday, I can say the range is as advertised or better. Wh/m since my last charge and after driving nearly 200 miles of freeway/streets with 2000 foot Gaines on a 45 mile leg on the freeway and back down.
This works out to 328 miles for a full pack which is more than advertised. The aero covers should improve a bit.
Although I drove 65-70 on freeway and speed limit on streets, energy management is key. For example, on a long down hill I coast by not regenerating nor using any power. If you see the green bar, you are regenerating. Press the power pedal slightly to remove regen. If you see the gray power bar go up, you pressed too far and are now using power. Sometimes going faster downhill will increase range because you stop regen and coast as long as you stay within the speed limit. Of course if speed picks up too much you must lift and start regen. Understanding the energy management is key for long range. I call this the Scott Dixon approach, if you follow Indy Car racing you will understand.
