Brake Malfunction; hit light pole
HUM469
Dylan
Sacramento, CA
CT Dual motor one day (position 71k on res. #)
Was the black aluminum fence just installed this past year?
Edit: i think you are correct on the location and the posts on the black fence do look fresh
I know I saw it under construction on one of my trips to the store just past the building in the distance. I feel like it was the last 12 months, but I wasn't exactly taking notes at the time.
Beyond
Rum River Watershed, MN
2026 Model Y AWD & Cybertruck Dual Motor order
So I know exactly where this happened, and feel absolutely confident that this was driver error. I say this because I can count at least a dozen other times I've seen this exact same crash at this exact same spot. I also imagine that the fence was added by SMUD in the last year because I've also seen cars go over the little grassy hill twice and take out employee cars parked in the lot when they don't hit the pole prior to the fence being built.
The OP was coming over an offramp from the freeway and making a left. The light for the left isn't immediately visible when one comes off the freeway as there's a curve and a climb. Constantly, people try to shoot the light here when they see it is changing at the last second. But the ramp and the road don't meet at 90 degrees, meaning the turn is much tighter than most. And like all the roads around here, this intersection is long overdue for a repaving, meaning it is pretty slick.
The OP came off the freeway, saw the changing light late, goosed the go peddle to not miss the light, then hit the brakes late into the turn, after traction was already broken, forcing the ABS to try to do whatever it could, which given the weight and the non-standard turn angle, was not much.
It's nearly a 7000 lb truck, off angle, on all terrain tires, going over the rise of the central intersection on very old asphalt. It was never going to make the turn successfully at any speed above 20 mph or so. Depending on the entry speed of the truck, there might have been some limit to the steering angle too, thanks to the variable ratio. But without OP admitting to the actual speed he crossed in to the intersection at, we can never know that particular point with certainty. But being as this crash is common at this location, it's not at all surprising that a CT would have the same problem as every other vehicle pushed too fast into this corner.
Thanks for the great location info. No wonder the property owners put up a sturdy fence.
FutureTruck
GA- USA
Tesla MX P, Lucid Air GT
For those asking about a diagram:
Incase anyone doubts I got the right intersection, note the building down the street:
Very compelling detective work!
Will be interesting if OP responds and what is discovered.
HellsNels
Nelson
SF Bay Area
ts.la
2024 Cybertruck | Beast | FS; 2017 Model 3 LR
Yeah I wouldn’t be able to see these lights going at speed (from freeway or gunning a light) that well either, then make a (corrected) ~70 degree left turn. Would make sense.
Tesla Cybertruck Brake Malfunction; hit light pole IMG_1389
FutureTruck
GA- USA
wow yeah that’s a dangerous looking exit ramp turn there. We know what happened now
We think we have another plausible explanation, so now we have at least 3 possibilities. Hopefully original poster will shed some light on it.
canyoncarver
Nunya
Earth
Cybertruck AWD
If he doesn't respond it's because Tesla proved the vehicle did not malfunction the way he claimed, OR there is pending legal action and lawyers told him to shut up and stop talking about it.
Edjcyberbeast
Edjcyberbeast
E
Sac
Self
Yes this was the location, but I wasn’t trying to catch the light, it was green. I let go of the accelerator way before the light.
I am still waiting on logs from Tesla, they also taking their sweet time with the vehicle. Will update as this proceeds.
Darth abbott
Mn
He has been vindicated if this recall is involved. Seems like it has only affected newer trucks?
Yeah this would make sense, if the accelerator pedal lubricant is a problem and the accelerator stays stuck down when you let off that would explain why the OP said the truck wouldn't break cuz it could have still been accelerating after he lifted off the pedal.
chilam
NY
P85+ Cybertruck Roadster 2.0 Founder's Edition
Let's not jump to conclusions here. The recall for the accelerator and this accident might not be related as all Tesla have Braking priorities. Even if Accelerator is stuck, the pressing of the brake pedal will cut the power to the motor as well and the hydraulic brake will kick in and stops the vehicle. Let's see the data that OP says he is getting. It *could* be a driver error (or it's not.) Let's see what the data shows.
Yes, this aligns well with what I said was the most likely explanation, excessive speed combined with a slippery intersection causing a loss of traction. We all know that when the tires have reached the limit of traction due to cornering forces that braking is not possible, the anti-lock brakes prevent further braking. The "delayed braking" is explained by this. Once the tires find traction, due to speed having been scrubbed off, braking could resume, but too late.
Two facts that were not previously known further support the excessive speed theory:
1) The intersection was immediately following an exit ramp of a fast-moving freeway. Everyone is probably familiar with the speed distortion that happens to your perception after slowing from a fast freeway drive. Specifically, after driving very fast on the freeway, especially for a longer drive, after exiting the freeway, 45 mph can feel like you are only going 25 mph.
2) The fact that the turn was more acute than 90 degrees. I didn't previously know that, and it supports the theory of the driver misjudging the speed required to safely navigate the acute angle.
Some other factors that may or may not have been involved but could contribute to the OP's surprise that the vehicle was no longer turning or braking. These are speculative and based on nothing more than being potential factors that would work against the OP's expectation that his corner speed was appropriate:
1) If the tires were under inflated, below 50 psi cold, it could cause the sidewalls to "tuck under" during corner initiation. When this happens, traction is dramatically reduced rather suddenly.
2) Suspension mode: I've been experimenting with my Dual Motor CT's suspension modes. The truck handles much better on pavement in the low "Sport" mode. The higher modes, including "Comfort" are more akin to legacy 1/2-ton trucks that have excessive body roll and a corresponding transfer of weight to the outside tires in a turn. This weight transfer can encourage the problem mentioned above, the sidewalls tucking under.
