Its from @greentheonly on X/Twitter.Do you have a link to any more info?
From where is the photo sourced?
Thx.
I hear what you are saying but it didn't look like the fronts did (center) either which is why I included that picture too. That horizontal shaft seems like it would hit the frame underneath during travel up and down it no matter what part it is.Are you sure thats not the rear steering rack and links? Doesn’t look like its in line with the center of the wheel. To me that only makes sense if its a portal axle drive. Any rumors or reports of that?
Typically you grab the image (compiled version of the code depending on the deployment platform) and run it through a de-compiler). If the source language was Java, then decompilers are fairly decent but for other non byte code (ie not interpreted like Java), the reverse generation can be pretty nasty.If I ever have time again. Id like to figure out how they explore the source code
Makes sense. I am going through a compilers course right now as a capstone. De-compiling never even crossed my mindTypically you grab the image (compiled version of the code depending on the deployment platform) and run it through a de-compiler). If the source language was Java, then decompilers are fairly decent but for other non byte code (ie not interpreted like Java), the reverse generation can be pretty nasty.
It's not a fun thing to read. Variables aren't semantic, etc.
