JesseDGreat
Jesse
San Bernardino, CA
2024 CT AWD Foundation, 2022 Model S, 2023 Model 3
Finance Manager
I got my replacement today but it still doesnt fit. Its exactly the same as the first one. It has the flat side on the outside of the pegs. Im thinking they sent me the old one
Fast Eddie 008
Edward
Wimberley, Texas
2020 Tesla Model X, 2022 Audi A5 Cabriolet
C.P.A.
I received mine today. It was on backorder. It doesn't fit except in the back where the storage compartment is. Arrrgh!
Cyber_P
Alabama
AWD Cybertruck
I've waffles on buying this so many times. I now want one again. But I'm sorry y'all got old lot. And I'm sorry the CS is so difficult as it's just another headache.
Love this truck though.
sgmorton
Sam
MS P100DL+. M3P, CT
Programmer
My divider arrived today... Yea same thing its to high in the back. I think I'm going to do the grind @okiebug posted.
popz41
SoCal
Beast
Mine arrived today, and only fits on the slots above the under bed storage bin. I'm bringing my truck in tomorrow for a door alignment, going to ask service if the bed can be adjusted.
sgmorton
Sam
MS P100DL+. M3P, CT
Programmer
Happy to report that the cut 1/3rd of the pegs posted above worked a treat. I used a dremel with a cutoff wheel and it took all of 5 minutes. Seems like it's locked in tight and solid and giving a hard push pull seems to have zero effect. I can lock in anywhere in the bed now front to back.
Boyne
Boyne City, Michigan
2018 MX, 2022 M3, 2024 CT
Retired Naval Officer
I have received the replacement bed divider and it seems to me to be identical in all respects to the original one. Identical part number too. Now having a spare, and because I installed a bottom bed linner, I modified the first one to fit. I used a drill to drill out rivets on the bottom that hold rubber pads on the bottom, and I cut off the top of the two buttons on the top of each side, so now it works well in every position. even with the extra height of the bed due to the liner I added.
popz41
SoCal
Beast
Took the beast to the service center, and they "adjusted bedside wall assembly", now my divider works all along the bed.
ninjadoc
Glen
PA
2012 Sig S; 2018 X 100D; 2023 Y
I received the cargo divider yesterday. It only fit over the bed floor storage area and in the last spot closest to the cab. I thought I was doing something wrong, and then found a few of these forum threads with similar issues after a quick google search. I ended up loosening the 10 bolts that hold the bed panel down, and then I was able to get the divider into position. I tightened all the bolts back down with the divider locked in place, and now can move it to any position along the L track. It is snug at all positions, and just takes some downward pressure while engaging the latch.
sharpgator
Scott
Birmingham, AL
26 AWD CT, M3
can you share the link for the bed loosening procedure?
sharpgator
Scott
Birmingham, AL
26 AWD CT, M3
I was able to order a bed divider a couple of weeks ago. Installed it today. It fits all the way back., Even with my elecfresh bed protector installed.
Here’s some pics. Is this an updated divider or is my bed just flat?
Tesla Cybertruck Fixed Vault Cargo Divider replacements being sent by Tesla IMG_2986
Tesla Cybertruck Fixed Vault Cargo Divider replacements being sent by Tesla IMG_2985
ninjadoc
Glen
PA
No specific online instructions. It just seemed to be the issue when I was trying to figure out why the divider was not fitting appropriately. I used a 10 mm allen socket at each of the sites circled. The tie down spots have the bolts exposed. I used a flathead screwdriver to pop off the rectangular caps covering the other bolt locations. I did not remove the bolts completely, but probably fine either way. This allowed me to get the divider in place with some coaxing. Once it was fully seated, then I tightened the bolts. Photos attached.
Tesla Cybertruck Fixed Vault Cargo Divider replacements being sent by Tesla cybertruck bed bolts
Tesla Cybertruck Fixed Vault Cargo Divider replacements being sent by Tesla 20240615_134546
Tesla Cybertruck Fixed Vault Cargo Divider replacements being sent by Tesla 20240615_134530
Speedr
Dual Motor Cybertruck
Awesome! Thank you! Will try this shortly.
Please reply to this if you try this and it works for you too.
Jbrazda
Juston
Valley, Nebraska
Cybertruck, Model Y
Builder
Got mine same as everyone else, it does it fit properly in the middle third of the bed. Can’t put it exactly where you would what’s it right behind the lower storage area. I’ll try to tighten the more in the bed and see if that helps.
