Texarado
Dallas TX
Found an air compressor and tank that fit in the space underneath the smugglers bay. Wasn’t the cheapest option, but works pretty well. Power is taken from the roof 48V using a 48v-24v DC-DC converter mounted inside the side wall.
Compressor: 200psi/24v VIAIR 330C-HG
Tank: 2.5gal VIAIR
What was the total cost? Time to install?
Pops
Houston, TX
MY, CyberBeast
Excellent work! I dont need a compressor enough to go through the trouble of seamlessly integrating it like you did, but I still find myself wanting it after seeing it.
Perhaps an alternate solution would be to build in a 2nd storage bay under the bed that uses the same space you did? I do not mind pulling out a compressor and plugging it into the 120v when I need it.
Reactions: Ed1
CTSoFL
South Florida
That's a great point, definitely not ideal (I've caught them on a few things and almost impaled a watermelon once).
The smugglers bay would be a great option but a pain to get to when the bed is packed. Eventually I plan to recess the connections and switches behind the sidewall with a small cover (similar to the power outlets on the opposite side).
What we would do on our rock crawler jeeps is mount the air attachments tucked on the frame rails or inside bumpers.
Any place for that on our cybertrucks?
Cyber Man
Very impressive. Based on how the thread title was worded, for a min I thought we found a hidden air compressor that Tesla installed there lol! Such a wishful thinking! You will never know - CT is a pandora truck. ?
Great job OP. ✌
Gogster2k
Gogian
Montebello, CA.
Dodge Charger, Honda Odyssey, Tesla M3, MY.
Retired. Tier II Desktop Support Tech, Southern California Edison
Tank: 2.5gal VIAIR
That’s awesome! You turned on of my wish list items into reality as I was also looking at the VIAIR on-board compressed air systems too. I don’t have the CT yet, but have been looking at what mods can be done. Very kewl indeed!
NXTruck
Illinois
X, Bronco, Ambo, Acela
Is it not possible to tap off the existing compressor?
That wouldn't be a good idea because the air suspension uses a higher pressure compressor (somewhere around 350-400 psi) designed for lower volumes. Tires need low pressure air at higher volumes. It's very inefficient to compress the air more than necessary to fill the tires.
I wouldn't tap into critical infrastructure like that since it's tied to the suspension.
DeBergo
Dan
Columbia Mo
Contractor
Tank: 2.5gal VIAIR
Very nice! Can you give us an ide on time to disassemble, install and reassemble?
Reactions: Ed1
webspeedracer
SLC, UT
Awesome build, thanks for sharing! I was just pointing at my wife’s Rivian compressor nozzle and saying I want that in my CT. Would you mind sharing your parts list, particularly the 48v>24v DC converter, you used?
aeroguy
VA
Is there a drain at the low point of the tank to drain the condensed water out?
There is, the solenoid on the left side connects to the bottom of the tank and vents out just below the hitch. The bottom power switch is a three position switch wired such that holding it in the spring loaded down position drains the tank.
