Is the 80% recommended charge real?
NealC
Neal
Tucson, AZ
www.flightcontroldesign.com
2024 Telsa Cyberbeast, 2026 Tesla Model S Plaid
I always charge by Cyberbeast to 80% because that is what I read online. I tried to find that recommendation in the owner's manual and could not find any reference stating this is actually recommended. I did read you should not allow the battery to get below 20% and if you are at a super charger, just charge to 80% so not to tie up the stall for someone else. If you have any documented Tesla information on this recommendation, I would love to know where it can be found.
Thanks
Reactions: TAD
Beetlebug62
Ken
Maine, USA
Thanks
Based upon 6 ½yrs with my Model 3, I think those recs are based upon utility. If you get below 20%, you have to be careful that you don't let the battery drain too low. But, you can certainly drive below 20%.
And, for daily driving you can charge to a lower level if you like. I charge to 60%, since that's what I do for my Model 3, and it works fine.
Lithium ion batteries are happiest at 50% SoC.
But charge to your daily needs. Easy day.
dalton108
Dalton
Lawyer
Being the thrill-seeking rebel that I am, I left town for two weeks with a 16% SoC.
I hope that phantom drain is low!
Sinner! You must atone! There will be electron bleed.
Tesla Cybertruck Is the 80% recommended charge real? IMG_5929
Hookalakupua
J
Reno/Bay Area
Take this with a grain of salt as there’s been a lot of discussion around just how accurate the Tessie App is. With that said, after 6 months and 12,000+ miles, with exclusive free supercharging (outside of 3 or 4 home charges), we’re still showing 100% batter health. This number does fluctuate by 0.5 at times. We consistently drop closer to 10-15% and generally charge to 60-68%. We’ve probably charged to 80% 6-8 times.
Tesla Cybertruck Is the 80% recommended charge real? IMG_9299
Tessie is only reporting the BMS data. The current theory is that the “degradation” is based on the advertised pack capacity, but each pack has some slight variance in what was delivered.
Enjoy your full-capacity pack!
Edphonse
Washington
2021 Ford F-350 4x4 CC SRW 6.7L Powerstroke Diesel, 2024 Cyberbeast
Looks like your tessie app is bugged or needs to be updated. That 0.00kwh under the circle graph should say 122.51kwh (assuming mine is correct at 122.51kwh which is basically what i have heard multiple sources quote as the pack size for the CT). Basically your tessie is dividing by 0 so it is showing 100%. Regardless, you are at less than 1% degradation, which is pretty good.
Screen says 80% recommended for daily driving, consensus is wandering outside of 80/20 is not good for long term battery health.
No big deal if they fix the charge curve, still waiting for 500kw a year later
Tesla Cybertruck Is the 80% recommended charge real? zimage10462
It's still a big deal when it takes more than 60% (80 to 20), 80%, or 100% to get to the next Supercharger...
Mikec3399
Waterbury Connecticut
School Owner
I currently own 2 FS Cyberbeasts, one with free supercharging, and the first one for almost a year without free supercharging, I treat them like a cell phone, I supercharge on long trips up and down the east coast from Connecticut to Gainesville GA, I only supercharge only to 80% but when I leave for a long trip, I charge at home at 6-7 amps to 100% to get those extra few miles in.
slow charging works best for me. sitting at the supercharger, I just charge too what I need to make it to the next supercharger.
240 Volts at home 32 amps is plenty and I usually bring it way down to 6-7 amps to top off my batteries.
I'm installing power share soon, so that will definitely have an impact on how I currently charge. it's a learning curve, just as when you add solar to your home, you change your everyday habits to maximize efficiency.
