PCS Failure - Can’t charge at all
JCERRN
J
Around
Yeah
The replacement time for Cybertruck PCS is 4.2 hours which is less than the 2021+ Model S time of 4.62 hours.
If the Cybertruck was a three row SUV, it would be under the seat, but the aux bay is under the tonneau roll up mechanism. So cover and air tank need removed.
I suppose if one were to buy the right tools and were motivated to, they could do the swap in their driveway.
Oh, definitely. Especially since Tesla has subscription options for the diagnostic software.
PCS is $1,785 from Tesla and it let me add it to my cart.
You wanna swap out your own PCS? I'll subscribe to that YouTube channel :ROFLMAO:
webspeedracer
SLC, UT
May this never happen to you. I have 138 miles to last me until my service center appt on Monday. Even though Grok says I can usually charge at Superchargers, I just tried and I cannot. It says supercharger failure but I tried a different one and got the same message.
My home charging ended early and threw up a message “AC charging unavailable”. Service center appt required. I made the appt but the earliest is Monday. Nothing unusual about my home charging or state of charge being too low or too high.
I have 51,000 miles. I’m out of standard warranty so hopefully this will be considered part of battery drivetrain warranty. Grok says it could go either way and if I have to pay it’s around $4k.
OP did you have any PCS-adjacent symptoms or prior incidents before this charge failure?
I’m at 49,3xx, recently had a power failure on the freeway that is making me nervous with your current quandary and price tag. My SC said it was just a voltage-low situation (I was approaching a Supercharger at 2%), not a PCS failing. I’m skeptical, have done that same approach to supercharge at low SOC countless times.
kpanda17
btw, they stated my service menu log was littered with errors, my only big beef was only getting max 105kw at a TSC
CapheDa
CapheDa
Dustin
Brea, California
2018 M3, 2023 M3P, 2024 CTFS
Investor
Yes I have. Rear inverter went out and had to be towed in and replaced. The screen went out (different event) completely after a week or so of error beeps and blinking on and off. Tonneau and tailgate buttons had to be replaced (different event). Plus I had all the recall fixes like front overhead console, camera fan, wire harnesses, etc.
I have a whole list of repairs that have been done since March 2024 when I took delivery. I love the truck but I think it’s also a “lemon”.
What type of power failure?
PCS would cause 48V issues if the DCDCs both went bad, but that's separate from the ACDC charging section.
Yes, but I don't own a 2021 S. 1.5 hours for a 2017.
Replacing the onboard charger on a 2017 Tesla Model S typically takes 1.5 to 2 hours of labor.
The process involves disabling the high-voltage system, removing the rear trunk trim or seats (depending on the specific configuration), and disconnecting coolant lines. If you are having this done at a Tesla Service Center, expect a total appointment time of 3–5 hours including diagnostic and testing.
Again just lift the seats and you pretty much are done. Yet you don't have an S Nathan. Just doing the Google searches.
Edit add:
So again why did Tesla make it so complicated for a PCS swap when the old on board charger swap was easier.
Yes the PCS is a different animal, but the failure rate seems to be pretty high even though a non scientific sampling.
That's the pretty sad part about this forum. You all never experiencing anything anymore. You don't even own the vehicles that you spout so much information about You just go off to Grok or Gemini and search it up. Keyboard experts of nothing. Come on mongo that's what you did for what 10 years over on the Tesla TMC forums?? Never own anything except for just Google it up for 10 years straight.
Well yeah, I never made a secret of the fact that I didn't fit in nor own any Teslas pre-Cybertruck.
As to why Tesla changed the architecture of separate charger modules to PCS, I'd guess there were a few reasons:
The under seat setup was vulnerable to liquids spilled in the back seat
The process required unbolting and refastening a bunch of HV connections
The overall assembly was much more expensive and complex than an integrated unit
Minimal isolation from the HV to the cabin in the event of a fault (somewhat similar to old VWs with the battery under the seat) .
CapheDa
CapheDa
Dustin
Brea, California
Investor
UPDATE:
I had a conversation with the site manager of tesla Anaheim last night. He said they cannot cover it because I’m out of warranty. He’s truly sorry. I pick up the truck today at 5 o’clock. I will have to pay the $6400.
As someone suggested, I made a tweet to escalate my issue. I would appreciate it if anyone here would comment on it for extra visibility.
Tesla Cybertruck PCS Failure - Can’t charge at all IMG_7215
UPDATE:
FYI, if you start an X post with an @ tag it limits visibility, that's why you'll often see posts eith s period first then the @
Jbrazda
Juston
Valley, Nebraska
Cybertruck, Model Y
Builder
UPDATE:
Doing it now. And tagging some big Tesla influencers.
Jbrazda
Juston
Valley, Nebraska
Cybertruck, Model Y
Builder
UPDATE:
Add a word before you tag wes. Or even period.
