Road Damage to Rocker Fairing
Ward L
Ward
Camarillo, CA
Model Y, FS CT AWD
I ran over a relatively small chunk of truck tire on the freeway last week and it damaged the right rear wind flap. That is prolly not the name of it, but it is the piece hanging down in front of the rear tire. When I first saw the damage, I couldn’t imagine how it happened. I tried to push it back into place and of course it is not easy to do and I was not able to fix it. I don’t like the plastic bumpers and plastic body parts around the wheels just for this reason. I think they are a little on the flimsy side and prone to damage. I will try again to fix it or take it into the shop for repairs.
Tesla Cybertruck Road Damage to Rocker Fairing IMG_3087
I get a lot of positive feedback from others when driving this vehicle. I’m happy I have it and enjoy driving it. One of my worries is that it will fall apart over time. It is a challenge to keep clean. I really don’t do windows very well, and that shows up pretty clearly when I clean the windshield!
jf64k
My SC replaced that part (Rocker Fairing) for free when I had mine in for wiper motor/sail applique recalls.
The part was $15 from Tesla when I replaced mine. There are four T-20 screws that hold it on. To get to them you need to partly remove the rocker cover. You can leave front wheel fairing attached, then remove six 10mm bolts from bottom of rocker, pull the lower corner of rear wheel fairing off to access another 10mm bolt. Also remove one push pin from rear liner. Then pull rocker toward you and you can access the screws.
https://service.tesla.com/docs/Cybe...UID-D0420707-8D36-4266-9B2A-4B636FBA962E.html
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
Lots of groups coming out with lightweight aluminum replacement parts, rock rails, bumpers, etc. Should see them coming out over the next few months.
I've also broken my wind block things. Just planning on aftermarket rails and bumper when they're soon available.
Plastic is easier to replace and less likely to get hung up and damage something important. It also does less damage to other things when you collide with it.
These parts reduce the number of rocks which damage other vehicles - like the rock that chipped my windshield last weekend for a $80 repair - and increases your range by filling voids and redirecting aero around the truck.
Tho Cybergus's idea of a different material is an interesting one.
Agree on first part about breaking first.
These are in front of the wheels and do nothing to stop rocks from being kicked up at following vehicles. For that you need the $100 set of mud "flaps".
sefar
se
Missouri
Model S 100d, Cyberbeast FS
Do you happen to know the part number?
M0unt41nm4n
Durango, CO and Moab, UT
Yeah I thought they were $15 too. Is $94.20 with labor?
mine haven’t gotten struck or anything but they have horrible road rash and a pitted to hell. When they finally perforate, I will replace mine.
UP_Kirk
Kirk
Hawthorne, CA
Model X, Cybertruck AWD
Unplugged Performance - Tesla Specialist
At @Unpluggedperformance we have Hardened Steel accessories for the CT.
Rocker Panel / Rock Sliders are one of many options. Let me know if I can help you with our superior CT Products. Take a look at https://unpluggedperformance.com/cybertruck/
