- May 27, 2024
- SE Michigan
- Cyberbeast
Yeah, we have dual 200A panels and will need to repartition or go with something like Span to make it fully automatic. Although, if the Cybertruck is home so are we and could flip off the extra breakers manually...Thank you for the follow up. That makes good sense.
I get your point about two+ Powerwalls and two Gateways but in terms of the Cybertruck
I think it means the CT connects/talks to one Gateway which talks to one 200 amp panel.
I think that means you have to be sure all your critical loads are in one 200 amp panel similar to having a generator subpanel.
I was hoping to get away without doing that but it sounds like it is what it is. There are other options like the https://www.span.io/ panel which lets you dynamically control which loads are used. As well a similar setup with Lumin Edge to dynamically control circuits. https://www.luminsmart.com/lumin-edge
The utility person I've spoken to at our likely future home site also mentioned the 320 ("The 400 amp service is a 320 amp meter socket (320 continuous).")
In any event, thank you for the additional clarity as I thought I hit a complete road block but it sounds like there is just more planning required (main panel and critical load panel on the Tesla gateway).
