- Oct 3, 2020
- Western Washington, USA
The number one cause of blowouts is low tire pressure. Old degraded tires and hitting objects in the roadway, often in combination with low pressure, are also causes. A degraded tire could be due to low tread depth due to a lot of miles, uneven tread depth due to misalignment, too old (calendar age), it could have been run at too low of a pressure or overloaded for part of it's life, especially in hot weather or at high speeds, most likely a combination of the above factors.You got me thinking, I wonder what is the #1 main cause of a tire blowout....tire pressure? Object in the road?
It's exceedingly rare for a tire to be defective enough in manufacture to blow out, especially without one of the above factors compounding whatever minor defect the tire may have.
From this it should be clear that blowouts are almost always self-induced or, in the case of a used vehicle, caused by the previous owner. To almost guarantee that you will never have a blowout, follow these simple common sense rules:
1) Buy quality tires of suitable size, load, and speed ratings.
2) Keep inflation pressure appropriate for the load and speed at all times.
3) Maintain tire alignment.
4) Replace tires low on tread or with excessive calendar aging, cracking sidewalls, etc.
5) Avoid road hazards.
Following these common sense rules will virtually guarantee you won't have a blowout because defective tires are exceedingly rare these days. Modern tires are so good you could break every rule in the book and you still might not have a blowout. But that just increases the chances dramatically.
Tires need a higher PSI when loads and speeds increase, particularly in hot weather, to limit temperature rise, a primary cause of blowouts, and tire degradation that leads to blowouts. Remember, you will probably temporarily "get away with" running too heavy of a load, at too high of a speed, with too low of a pressure, on a hot day. But you will dramatically age the tire, which could lead to a blowout next year, even if everything is in spec when the blowout occurs.
Treat your tires well, and they will treat you well.
