Tallgeese179
- Nikola
- Sep 11, 2025
- Pittsburgh, PA
- 2025 CT AWD, 21 BMW X7, 15 370Z Nismo
Laws might vary state to state about placing coverings in front of headlights and you also need to consider unwanted effects like unwanted reflections and how those could turn into something like a strobe from a flat piece of reflective material vibrating as you go over bumps.
If we were only dealing with light snow, something like an air scoop could work: capture air hitting the front of the car as you move and blow it tangential to the face of the headlights. Something like the ducting Tesla uses on the front bumper bottom corners, to create a cleaner air curtain across the faces of the wheels.
Alternatively, adding headlight spray washers would likely be very effective regardless of snow type and would help freezing from occurring. Just need some programming/logic to trigger sprays before the build up becomes excessive. Could plumb it to the front camera washer for manual control and easy tapping into the pressurized side of the washer plumbing.
A resistive heater glued to the backside of the bumper shelf directly below the headlight would do the job...just seems wasteful in terms of energy used.
You could always cut a hole out in the shelf below the headlight. Much harder to accumulate snow over an unsupported span
