- JB
- Nov 22, 2019
- Australia
- Cybertruck
- . Professional Hobbyist
So that makes sense if the problem was "not enough generation", and to source that from somewhere the load is not high, but it still doesn't address the actual problem being that the Cal distribution network can't support the load through their network. You essentially have power at the superconductor end, but still can't get it to the consumer end.Why I proposed a superconducting trunk is that power use is very time dependent and while it might be hotter in one part of the country, it is not always hotter everywhere in the country, so being able to shift power demand and supply and using batteries to also help time shift, it could be very possible to provide extra power to a regional/sub grid for other areas/grids. Like taking power from the plains states with lots of wind potential to other locations. There are times where even here in Indiana (northern part of the state) with wind turbines are idle or not producing power because there is not enough demand sometimes... the trunk would help shift that power to other states, to industrial areas, etc.
As for Maglev trains, fine, if the superconducting bit is on the train, but for super colliders, it is still miles of tunnels, superconductor, and such.
We (the USA) is so far behind in rail technology, that even just having a decently high speed train would be better than anything else we have (decently high speed being over 100mph). Yes, if you have a trunk bringing along power, then using it to help energize maglev hyperloop should work...
Are not maglev trains powered externally?
Installing local, distributed embedded peaking or storage based generation actually gets power into all the parts of the "weak" network so customers can get their power. Think of it like a powerwall, where the house can use its own storage and exerts zero load on the network.
Overall your thinking is correct to make better use of renewable generation by allowing better distribution, but you can also to this using the time shifting with storage. The biggest issue overall is simply time of production vs time of use, that cause network peaks 3-5 times base load. As you can imagine its super expensive to oversize networks to work for peak, whilst predominantly only supplying baseload.
We need to kill the network peak.
After WW2 in Europe many countries limited large appliances from running during peak periods, even things like household washing machines were limited. Funnily enough that training resulted in a long lasting peak flattening over some generations. We also have the opportunity to use DSM (Demand Side Mangement) to throttle or limit peak use, but it can get fairly intrusive at times , reduces productivity and increases customer dissatisfaction. With that the network has the ability to disable certain circuits and appliances in the house or industry.
More recently since the advent of air conditioning and house climate control this type of limitation is highly undesirable, even if you get paid for if they use DSM to shut off your air-conditioning. Here another storage solution would help, and that is storing heat or cold in very cost effective, low resource use, insulated water tanks for use during peak electrical loads, meaning air-conditioning does not add to network load or peak, but still operates to climate control your house regardless. The other benefit is that the air-conditioning, at least in summer, can either "charge-up" the thermal storage directly from solar without batteries, or use off peak power at night, where the air-conditioning actually operates at a better efficiency as well.
From a network perspective this would be a huge improvement, plus it would reduce and improve household consumption and climate control running costs for households and businesses. If it was me creating gov polic and spending dollars, I'd rather invest in that instead of upgrading networks. Much better bang for your buck.
BTW in South Australia they are doing something similar by subsidizing household Powerwalls to operate as a VPP. They just need to get on the thermal storage bandwagon, as it's much cheaper to deploy.
