Tinker71
- Ray
- Aug 8, 2020
- Utah
- 1976 VW EV bus, 2007 Sienna, Tesla M3, Cancelled CT2 rez - holding for $65k
- Occupation
- Project Manager
- Thread starter
- #16
I don't recall when, but I think the plan was to truly double stack the 4680 cells not metaphorically. It would be cool if all batteries were rated as "adjusted pack level energy density" This would be kWhr/mass of the entire pack with a credit for structural material that is able to be removed due to the structural nature of the pack.I think this is relevant to this discussion. The CT will use 4680s, which are 14% taller. So effectively the CT battery would be "14% double stacked" compared to a Model S. Taking it a step further, the overall packaging of the new cells means more energy can be packed in the same size pack. Sandy Munro estimated it at around 50% more storage. If you're at 100kWh for a Model X, you're up to 150kWh using 4680s on the CT. The truck is bigger, so maybe you can fit some more cells in there, and you're up to around 175kWh. Then, Tesla estimates the weight savings at 56% from he new battery, and the corresponding range bonus is 16%. That would mean the equivalent of a 200kWh battery with no stacking. That probably gets you to that 500+ mile range, with far less cost, weight and energy use than we're seeing from options like Ram.
