Cybertruck 1974
Everywhere
The Cybertruck only has a single 48A charger onboard so a 60A circuit is all I needed for the UWC. The mobile charger maxes out at 32A.
My old Model S had two 40A chargers and could use a 100A circuit. Its mobile charger could do 40A.
sorry, my mistake. I was asking about the capacity to charge the truck not powershare. Wrong thread I guess. Well since Im here, what is the max output a wall charger can give the truck?
agordon117
Ohio
cybertruck foundation awd
48A is the max in and out from AC.
agordon117
Ohio
really? I guess I'll get a supercharger from supplier and install at my house with 200amp subpanel
DC charging would indeed solve the issue, but even if you CAN find a place to buy a supercharger, you need a lot more than 200 amps. And it's probably gonna run you 50-100k.
Having said that, there IS a place that makes a DC charger that has its own battery pack, so you can trickle charge the battery on it, and then fast charge your car from that battery. But, it's going to be expensive like I mentioned above.
Cybertruck 1974
Everywhere
I build gas stations and the fuel equipment suppliers have started selling EV charging stations and being a licensed contractor I can get the equipment at 30% off. That being said, a 200amp subpanel off the main is easily done. 150+amps is way better than 48. I'll post when done.
Cybertruck 1974
Everywhere
Well, so disappointed as today I received an email that i won't be getting my Power Share Equipment installed and only a $700 credit.........I thought we paid more than that and all this after I did receive in January an approval for Power Share. Disappointed.
Thank you for completing the Powershare Home Backup survey. Because you already have Powerwall installed, your home is on the way to being fully configured for Home Backup.
To finalize your Home Backup setup, you need to have home charging backed up by your Powerwall. When using Powerwall, Home Backup is compatible with any home charging unit, but 240V charging will provide the best experience. Our recommended home charging solution is either Wall Connector or Universal Wall Connector. To confirm whether your home charging is 240V and backed up by Powerwall, follow the steps below.
In place of Home Backup equipment, you will receive a $700 voucher for Tesla Shop. You can use this voucher to purchase home charging to complete your Home Backup setup – or to purchase other charging equipment, apparel, accessories and more. For help installing your preferred home charging solution, contact a Certified Installer listed on our website.
Daryoon
Cybertruck, Model X, Model 3, Lexus IS-C
I’m not please with that either. The value of the credit should be for Universal Wall Charger + Gateway 3V. That’s much more than $700. Likely $2000 or more.
Tesla pulled a bait and switch whether they realized it or not.
Cybergirl
Illinois and Arizona
RJ Electric notified me about scheduling a site evaluation to install the Tesla Powershare system.
In my case, I already have non-Tesla solar and battery backup. I have a Sunny Boy solar inverter, a Sunny Island inverter/charger, and a 9.6 kWh battery. If I cut back on loads, a fully charged battery will see me through the night until solar production resumes the next morning to recharge the battery. The Sunny Island detects loss of utility power and disconnects the main panel from the grid. When grid power returns it reconnects after a time delay.
I want to install the Tesla gateway between the utility meter and my main breaker panel.
Typically, my CT will not be connected to the UWC, so my existing backup system will respond to a blackout instantly. If I'm home (spend winters in Arizona), and it looks like the power outage will be prolonged, I can plug the UWC into the CT and supply up to 11.5 kW to the house. The Sunny Island will detect 240VAC power from the gateway and switch modes to recharge the house battery from the CT battery plus the solar panels.
This should be a simple installation since everything is done on the exterior of the house, including the mounting of the UWC.
Here is a simple block diagram of my existing solar system with battery backup:
Tesla Cybertruck Powershare Install Completed System Diagram with Autoformer
ArizonaTea
BMW/Mercedes
Hi OP, what is the panel size you have? I have 110A panel size and approved in survey. But my installer said they cannot do powershare on 110A panel and need at least 200A. They hold the project for now waiting for Tesla to provide a solution called load shifter so they can install poweshare on 100A panel. I have no idea if thie is true or not. And who know when Tesla can provide the solution.
schmo
schmo
Doug
Tesla Model S, Cybertruck AWD
I have a 150A panel. The Tesla Gateway is connected to the panel with a 125A breaker. The gateway has three backup circuits inside:
60A - Subpanel
30A - Downstairs AC
25A - Upstairs AC
schmo
schmo
Doug
@Cybergirl has your install been completed yet?
skinzy
scott
knoxville, TN
Porsche 911,Ford f-150,Porsche cayenne, CyberTruck
For those of you who have installed power share or received a rejection email when did this occur in the CT timeline. In other words did you get notification or installation before your CT was delivered? If yes how much advance notice were your given?
Obie_fl
Tom
2018 Model S, 2024 Model Y, Cybertruck FS AWD
I ordered my AWD on 3/12/24. (No idea on actual delivery date)
Survey came on 3/20/84.
Contacted by EV Pro 3/29/24.
Appointment with EV Pro set for 4/16/24.
Received eligibility email from Tesla on 4/5/24. (Note EV Pro reached out before I received the eligibility email but before the site visit/estimate.
schmo
schmo
Doug
Ordered 12/9
Survey 12/15
Approval 1/10
Delivery 2/15
Contacted by installer 2/19
Second approval email with installer name 2/22
Installation 3/6
