Tesla Powershare Home Backup Installation For $9,082.00 In FV SoCal For My AWD: Too Much?
agordon117
Ohio
cybertruck foundation awd
I just called, but I did not get to speak with the Lyndhurst store themselves I am guessing. However, they said my truck was in transit and they estimate early April for delivery.
My wife likes the stainless steel look as well, but my biggest concerns are the staining from bugs and bird droppings. Also, I am worried about the salt given our winters. Where are you getting the tinting done?
barkeeper's friend *should* remove the stains, but that's why I'm gonna do the protectaclear. So I don't have to BKF with every wash.
The place is called "factory auto tint" in mentor. Everything I've found says that Autobahn makes heat rejecting tint with the best clarity (only drawback is price), and there were only 2 places in 50 miles offering it. I was quoted 2800 for the most expensive tint that Autobahn makes, for everything but the rear window.
cyberHoward
Northern Ohio
Cybertruck AWD Foundation
Sorry for the million questions, but why are you interested in the tinting. Is it to reduce heat therefore increase distance and protect the inside or is it also for the look? It looks like the protectaclear is a home kit, that seems reasonably easy and beneficial. I even saw a post that you could apply Vinyl on top and it adheres prefectly without removing it. I really appreciate learning about these products!
https://www.everbritecoatings.com/tesla-cybertruck
agordon117
Ohio
No need to apologize.
I already sweat a bit while I'm driving my model Y on the highway in summer. Part of it is my fault, I always wear black shirts. But it just doesn't matter what I set the climate to, I end up with a sweaty back by the time I get where I'm going (if it's an hour drive or more). Part of this would be solved by the ventilated seats, but with the windshield being as enormous as it is, I figured it would be best to just get heat rejecting tint. I would have done it on the model Y as well, but that was always a placeholder vehicle for the truck. So it would have just been money in the shredder when it came time to trade in.
I don't care about the look that much. Full windshield is illegal here, so I'm not gonna push it trying to match the front windows to the rear. I want to skate under the radar. The guy recommended going with Autobahn ceramic i3 at 70% for the windshield, and I figure I may as well just use the same stuff all around since I don't want to go darker than 35% on the front windows. I just know if I go 20% on the front windows (to match the rears), I'll get pulled over, and if they find the windshield tint that's a bigger ticket.
Tesla Cybertruck Tesla Powershare Home Backup Installation For $9,082.00 In FV SoCal For My AWD: Too Much? IMG_2986
How much to install the Wall Connector? Who cares, shut up and take my money :ROFLMAO:
I got a quote for about $8k including the 200A panel upgrade. The problem now is waiting for the utility to disconnect the power, which is scheduled for June. sigh
cyberHoward
Northern Ohio
The pricing for the wiring seems a little much. I looked on the website of the installers for Ohio and they are saying $5k - $15k for running a couple of big wires between short locations. It is a 4 hour job max, so $1k an hour is ridiculous. I hope I can figure out how I can get the equipment myself. I understand when there is large runs of large wire where there is a lot of cost in wire. For my location, it is likely less than 20 ft of wire for all of my runs. I know it requires programming, but how hard can that be.
agordon117
Ohio
Unfortunately it's impossible to get the "included" equipment without paying their chosen installer.
Super annoyed about that myself
cgladue
Chad
Massachusetts
Software Architect
Yep, Lyndurst pickup.
I guess I won't be able to run two AC units - my upstairs and downstairs air conditioners at the same time if there is an outage :(
BTW, do you have your VIN or truck yet? I have a VIN and waiting on delivery dates.
you can run both air conditioners .. you just need to install a soft start kit. like this one https://www.amazon.com/EasyStart-Co...pcontext&ref_=fplfs&psc=1&smid=A2VHGGOHXF24LJ
one per Outside Condensor unit. makes your AC use less then half the inrush current it normally would.
DumpsterFire
Utah
Mouth Breather
Still no answer yet for my question: If I refuse the installation what'll happen?
Maybe the answer is “no one knows.”
You could refuse the installation and answer your own question though?
MyFirstElectricTesla
SoCal
Benz
I know. Already sent a few questions in an email to Trout but no reply yet probably because of the weekend. Looks like everyone here accepted the installation.
SolarWizard
MB
AWD
Ill have approval in 90-120 days for socal
Same bid from us would be $12-1500 less
igs
CT, MX, MY
Sirkevin
I installed my own wall connector it cost me less than 100 for breaker and wire. And plenty of YouTube videos on how to do it
My first quote to install the power share was around 5000 from tesla . I rejected it because knowing what it takes per requirement and the labor involved the quote was mostly profit.
I can't see any install that doesn't require a major rewiring to cost more than $500 labor for highly skilled electrician to spend a day on site
what I plan to do is install a new panel adjacent to my existing two panels run all the breakers that I want to be on the back up to it and use the cut off switch to power the single panel. just like you would for a generator back up.
it will require a permit with two inspections in cordination with the power company to do a meter disconnect and reconnect.
diy cost will be around $1000 max.
Sirkevin
a suggestion, get a local electrician to do all of the upgrade work and prep work in advance and then have the Tesla installer only do the power share install.
