Wind noise with new OEM lightbar install
ViewyHippo
NY state
Cybertruck, Model 3 LR
I just got the new lightbar installed and working. Super bright and should come in handy when needed.
Unfortunately, I’ve noticed a high pitched whistling coming from the area of light bar when I start going at highway speeds. I just wondered if that is too be expected or something that might be fixable either DIY or at Tesla Service. My truck was super quiet with ANC enabled.
Thanks!
agordon117
Ohio
cybertruck foundation awd
That's pretty common with Jeeps that have light bars. I would imagine this is a bigger problem with the new mounting brackets vs the old glue only install. So you'd need to make sure anyone telling you "no it shouldn't happen" has experienced it with the new version that has the brackets rather than the glue only version.
JCERRN
J
Around
Yeah
I think this would be difficult to prevent unless the brackets were perfectly flush. You could try adding a bead of silicone caulk or something to the edges to smooth it out but no idea if that will fix it.
It’s not normal even though @JCERRN is right; hard to prevent but not impossible . Mine is dead quiet. Take it back and let them figure it out. If they tell you they can’t reproduce it, get one of these fast track return tickets and harass the shit out of them. It’s an expensive install not to get right even if it’s on Tesla’s dime.
ViewyHippo
NY state
With the new install, should there be a small gap between the lightbar and the glass?
Hard to show with camera but I was able to easily slide a piece of paper under to show.
Tesla Cybertruck Wind noise with new OEM lightbar install imag
jf64k
Is that paper slid under your lightbar?
If so, that‘s absolutely not correct. There is a continuous stripe of VHB across the front, and two strips with about an inch of gap along the rear.
ETA: OP, that’s where your wind noise is coming from!!
JCERRN
J
Around
Yeah
Correct, there is supposed to be one continuous strip across the front and the back one should have a small gap where vent is on the bar (in the middle)
ViewyHippo
NY state
Thanks for the feedback. I’ve contacted service and will take it back to get it checked.
Schroederhc
Bud
WA
R1T, Juniper & Taycan
Self Employed
Haven't noticed any whistling with mine yet.
CyberTexas
Great state of TEXAS
Physician
Mine is quiet at any speed. In fact, BEFORE the install, I had a screeching sound whenever there was a cross-wind at high 70+ mph speed. AFTER the install, no more! So, the light bar has made my CT quieter! Go figure.
dalton108
Dalton
Lawyer
Thanks!
not normal.
FlightMJ23
MJ
NJ
Cybertruck, Plaid Model X, Model Y
Same problem here - taking mine back in 2 weeks.
